Good general purpose tires for an 05 forester?
bobbotron
Ottawa, Ontario, Canada
So last night I got a flat on one of my old geolanders and the tire place proclaimed it dead today. They're 7 years old, so it was time for them to go anyway but now I'm looking to find a replacement set of 4 tires asap!
I drive 97% on road, but want something that wont be wretched on dirt roads and will be tough. I think I'll stay the stock size, I have a manual and don't want 1st to be any taller. The tire place has cooper CS4's in stock, but I've heard these are a pretty poor choice on dirt. Strongly considering Yoko Avid Envigors, any thoughts on these, or other recommendations? I'd love to get some Yoko Geolander AT/S tires, but I think these are way overkill considering my foz spends most of the time in the city...
CS4's- I'm pretty sure I had them on my car. Zero wet grip, even with lots of tread. I replaced them they were so bad. I recently offloaded them to a tyre dealer who sells second hand tyres. I put on Toyo Tranpath MP-4's which were a noticeable improvement. They are a road tyre, but have never been a problem off road. However, their wet weather grip does not appear as good as they were when new. It's not a tread depth problem as the road was not that wet. But it is still acceptable for this sort of car. Maybe I'll try and get some Bridgestone RE002's- be nice if they came in that size.
That's interesting, I hadn't heard that about the CS4's up to this point... I've asked my usual garage what they think, they're going to get back to me with some options.
Hearing good reports on Maxxis and will probably give them a try next
Gidday Bob
Just lost 15 minutes typing due to my defective broadband line ... grrr :furious: :mob:
I have been there, done that. I also have much the same usage pattern as you.
Geolandars have reports of mileage between 35,000 to 55,000 kms. Ugh!
Noisy on-road according to some.
Handling and braking "Not as good on-road as a proper road tyre" according to some.
I opted for Michelin XM-2 because of:
  • Silica based compound
  • low rolling resistance
  • low noise on-road
  • superb handling on-road
  • reports of no staking off-road in 4,500 kms of bad staking off-road use (Tweaksta)
  • reports of mileage (XM-1 on Foresters) of between 65,000 and 90,000+ kms
  • No complaints so far after only 450 kms.
I did a simulated panic stop on a wet road the other night. Only thing that let go was my left shoulder. Great directional stability (only loosely holding the steering wheel). ABS didn't activate. No slip at all - just like stopping on a dead dry road.
I also had a 4 wheel alignment done. It was significantly bad. I bought the car s/h before Christmas last, so had no idea of whether the alignment might be correct or not. It wasn't. No point in aligning worn tyres IMNSHO.
The wandering and sloppy directional stability I had with the Pirelli P7s has vanished. Ditto for braking. I am running the Michelins at 35 psi all round, same as P7s.
At the January Bunyip SP near-disaster, NL and I had the same grip - absolutely none (he has Geolandar AT-s).
try the yokohama geolander g900 i think they are. they are standard fitment for the forester and outback here in aus. its a road tire that is a little bit more chunky for dirt road use
RB, dont forget you have standard suspension whereas I have raised (stiff) suspension, plus you have a rear LSD in good working order. That alone gives you more grip. Plus you have way more experience offroad than me. However, we did have similar grip descending the Phasmid Tr. I think you would have been shocked at the difference our tyres would have made ascending. There's no doubt at all the chunkier and deeper tread pattern of the Geo AT-s gives way more grip than highway tyres. Beyond doubt lol :iconwink:
bobbotron, in your situation, I'd go with Yoki Geolander HT-s. I think they will still perform well offroad, just not as well as the AT-s. The "s" stands for silica, so both have excellent grip in the wet, but the HT-s will be better. The AT-s also has a factory puncture warranty, which one of the members recently claimed on and received brilliant care from Yokohama. I think the HT-s also has this but be sure you ask. Its a big selling point IMO.
The At-s are a little noisy but I dont think its bad. I dont think the HT-s will be any noisier than any other tyre.
Remember pretty much all tyres have at least good grip on dry bitumen, its when it gets wet, with a bit of an oily surface, going around a corner or in emergency braking, that you realise the dramatic difference between tyres. Its then you will get down on your knees and kiss the tyres for just saving you! :monkeydance: (Or curse them if you got less grippy ones) :furious::eviltoyou:
In the end its up to you. My recommendation is go for the tyres that give you the best grip in the wet, but still are strong enough offroad to not fall apart.
Oh no...sorry mate, they're nickname is "Geosquealers" lol :eek:
They don't have a very good reputation, many people wonder why they were ever fitted from the factory. Plus as OEM tyres, will be sure to be more expensive...more money for less tyre :shake:
ok thanks i havent personally used them but i was thinking if they were standard fitment they would be good
Gidday NL
I didn't notice the AT-s getting much leverage going up that mess, either. No more nor less than the P7s. Fortunately for me, they had just enough so that I didn't get run over when I fell flat on my face!!
Really, I suspect that short of fitting smaller rims with higher profile LT tyres (very expensive option), there just aren't any "real" off-road tyres for our vehicles. There are some like the AT-s that are reasonable, but skill and experience will still make up for lack of tyres, specially with vehicles that have technological advantages over my old '68 Landcruiser - big time! As you already said, just that rear LSD helps enormously IMO.
Consider that straight, dry uphill track we all took on that day at Noojee. Barry just couldn't get out of the starting blocks in his OB. I got around 3/4 km up the hill before turning around and coming back down.
We were both running P7s, but his hang angle in the middle and bum stopped him getting the momentum he needed to get a start up that track that went straight up the hill. I reckon Barry has more experience with this sort of driving than I have; but the Forester was better for that all-important first slope.
Maybe the rear LSD and extra grunt of the 2.5 L N/A donk helped me a bit there, too; but more likely just that I could get a better run up at it because of my better hang angle and rear clearance.
I do believe that you're right, that the technology and vehicle specs make a difference. Sometimes, just enough.
I have already noticed that the XM-2s are considerably quieter than the P7s. Probably down to the silica compound, as the tread pattern is very similar.
Absolutely right mate. SWMBO's Camry is now on its second set of Toyo TEOs. They are super quiet, and stop like baby poo on a nappy in the wet ... :lol: :ebiggrin:.
That's the reasoning behind my going with the XM-2s instead of the AT-s. 75% of the price; super quiet on the black stuff; excellent directional stability for both steering and braking; better on-road performance, with precise, excellent cornering; much longer life expectancy ...
Gidday Thunder
thats another recommendation for the toyo teo's
Only if his Subaru had metamorphosed into a Camry, mate ... :iconwink: :lol: :rotfl:.
Note that I chose the Michelins over the Toyos for my Forester.
Having got them, I also reckon that they are better for the Forester than the Toyos, and I expect to get a lot more mileage out of them. The 14" Toyos on the Camry are only good for around 54,000 kms ... :(
The Toyos are also a bit 'soft' on cornering. I like a tyre that bites hard and hangs on. The Michelins appear to do that, but I haven't pushed them hard yet, as still settling them in. I reckon I can still tell the difference though.
the toyos are the best tire i have used for onroad and are not to bad offroad. maybe they are a different tire for the 14's compared to the 16's are maybe its just that the camry cant go around bends.
also ive had mine on 30 thousand now and are only just starting to wear
Glad you like them :).
Depends on what you mean by "best", however. And trust me, the Camry is no slouch when it comes to cornering, for a 2WD car, of course.
If I had my pick of road tyres, in the olden days I would have picked Avon ... then Vredestein. But then, these tyre companies are now owned by someone else, and who knows what their tyres are like these days?
Apart from the Certis, I have always had good handling and mileage from Michelins. The Certis handled fine, just that their wear was bad. Nearly as bad as the Toyos on the Camry (56,000 for the Certis; 54,000 for the Toyos) However, not as quiet and comfortable as the Toyos, which are also considerably cheaper.
What is the tread depth at this mileage?
Also, some people seem to get miraculous mileage out of their tyres, but I don't drive quite like that ... :iconwink: :rotfl: :lildevil:
Glad you like them :). What is the tread depth at this mileage?
cant give you a figure, but most of driving is from ballarat to back home in gippsland so isnt hard on the tires so that could be why i'am getting such good mieage out of them.
Agree, re the Geosquealers. Bad everywhere- and prone to puncture. The RE02's are available for the Forester. I run them on my WRX in a lower profile and they are a really good road tyre. For outright grip there would be few that are better. I think I will make them my next tyre for the Forrie. Good news is that Bridgestone are doing a buy 3 tyres and get the fourth tyre free deal.
I used to run Toyo Teos on my old car (07 Falcon) and i found them to be pretty good, very quiet and great in the Dry, they only downfall would be they whernt all that great in the Wet IMO, but overall they where a good tyre, Its pretty hard to go wrong with Toyos..
^ I've seen how well the Toyo's are on an AWD subie. They grip like sh*t to a blanket in the dry. Not sure in the wet. I'd never go back to highway tyres for an offroad car though. I found the tyres alone made my car 50% more capable in sand, mud and on gravel. The Geolanders (AT-S not geo squeelers) are absolutely brilliant all round. I am yet to lock them up in the wet and as said offroad they are amazing.
:huh::huh:
You got that right !!
The Geosquealers (g900) are :censored::censored:
I wouldn't even put them on a push-bike
I agree.
I couldn't wait to get rid of mine :evil:
