NachaLuva
Product Developer
A while ago I upgraded my lights from from dim to dazzling!
I thought I might share how I did it. There is no cutting of factory wiring by the way.
First, the schematic:
Note Subaru wiring is "positive switched", ie, the current goes from the battery to the lights then to the switch on the lights stalk. I know this is counter intuitive, it should be called "negative switched" as its the negative earth that runs through the switch, but this is what all the literature calls it
The lights relays are connected to the battery positive via the battery relay. As the lights are switched on, it switches the factory relay to supply positive to the lights connector, which I have used to switch the battery relay. This then provides the positive to the low and high beam relays.
From the diagram, follow the original wiring from the original headlight socket. These wires are controlled by the switch in the light stalk on your dash. Remember these are earth wires. As one or the other is switched, it provides a ground for the relay to switch on.
I did the driving lights relay at the same time so it would be neater. It is controlled by a wire going from the high beam relay (switching side) to the dash swich, then back to the DL relay. The DL switch is wired with a little indicator light. Unfortunately, because of the way its wired, the indicator light is always on if the switch is on plus the lights are on, whether its high or low beam. However, the relay only switches on with high beam. Its a weird peculiarity lol
Note that the DL are wired conventionally, ie, positive is fed from the battery relay to the DL relay to the lights then earth. Unlike the headlights which are battery relay to the lights then to high or low beam relay then earth. I did this as I always planned on using HID driving lights and I think (?) they need conventional switching.
Wiring layout diagram:
Lights socket connector:
