Forester clock light
fayfam
Bacchus Marsh
Hi guys,
my light on my dash clock stopped working the other morning,
is there an easy way to replace the globe,
also both my front windows leak air when driving at mid to high speed, is this a problem with this design of the forester front doors being frame-less, any ideas would be much appreciated,
cheers-mark.
The wind (& I guessing noise also) from your front windows is probably from your guzzets (I think thats what they're called) They are the triangle rubber things near the bottom & at the front of your windows.
I know there was a write up on how to fix them some where.
I think it was on SF.org.
If I can find it, I'll post it up here for you.
Can I add to this or should I make my own thread??
My L series' clock sometimes is so dull I can barely see it, most times if beep the horn it comes good but I've noticed the digital clock is also slow. All just an earth issue? Strange no?
I found that link for you :)
There is also another link you might like to try if it's not the gussets.
How To: Replace Window Gussets
Solved window wind noise!!!!!!!
Loud Whistle when windy/ highway
Hope these help :)
For your Dash Center Storage Compartment Removal / Clock Bulb
go to this link https://www.scoobymods.com/showthread.php/dash-center-storage-compartment-removal-3802.html?t=3802
for the wind noise:
