also for what it's worth, and at risk of opening a can of worms. what were your plans with the car and manual or auto?
i bought mine to a budget with my dad. cheapest 2.5 we could get into, and went with auto because it was to be used for occasional beach trips. also had cruise control (not all forries had in price range)
manual's have better fuel economy. the low range unfortunatly is a bit of a gimic (not very low) you can get a ratio swap
https://scorpionsubaru.com/low.htm
i personally like auto in the sand.
manual also has 50:50 torque split to auto's 90:10 to 50:50 when slipping. so on a dirt road a manual will feel more planted with less understeer. unless you want to fiddle and add a c.diff lock like i did.
https://www.offroadsubarus.com/showthread.php?t=1348
if you plan to do moderate off roading, do be aware a forester has better aproach/ departure angles and better articulation. but what i found was for the money you'd be looking at the 2lt sf. no head gasket issues but a little less power/tourque. also the early foresters run 15's some may argue benifits off road.
hope this helps. but like i say, just my 2c.
