wombat
Hi all, just went out and bought myself a snatch strap and a 4.5ton d shackle for recovering from my towbar at the rear.
I just tried to feed the D shackle through the eyes in the front tie down points and its too fat to fit in( thats what she said
) So im wondering what size shackles are you guys using when putting an equaliser strap on to recover from the front of the car? Also if im using a equaliser strap on the front and using the standard tie down points is it going to be ok or should i invest in some subaextreme tie downs?
The pin on the 4.5 ton shackle is 19mm thick and is just a little bit too fat to fit, i just found these on ebay:
https://www.ebay.com.au/itm/D-SHACK...48?pt=LH_DefaultDomain_15&hash=item19c805b6b0
They have a 12mm pin and will fit through the tie down points, are 1.5ton enough to recover the car?
