sasquatch86
So I got an '83 GL wagon. Put the SJR 4" lift on and havent come up with a good solution for hooking the steering back up yet. Anyone out there done this?
4" lift?!
We need photos!
From what I've read in other threads I think you will need a steering extension which you should be able to get from where you purchased the lift.
Was it a full body lift or only struts?
I figured out the steering issue. I found mid '90s legacy and pulled the double jointed part of the steering shaft, cut it in half and welded about 5" of tubing to it. I should have done this ages ago. Next step is drilling my 4x140mm hubs to 6x139.7mm hubs!
I'm happy with the lift but would not spend that money again. It would have been very easy to make myself. I had some braided brake lines made and found some Puegeot rims to I didn't have to drill my hubs.
