Hi offroaders,
I'm looking to setup two Hellas as additionnal driving lights for longer ranges, however I'm looking for tips on the following:
- They must be easy to remove (the basket is removed for daily drive use)
>>> What kind of plugs I should use that won't fail with rain, yet that don't cost an arm (I've seen $100+ waterproof plugs...)
- I already have a set of driving lights on a lightbar (not wired yet, will be shortly) and I am considering adding utility lights at the rear of the basket for camping and other various uses in the wood
>>> How should I wire all that?
Attaching them to the roof basket will be easy so there's no issue on that part.
Also, I was considering using the central console's empty switch slots (see attachement) instead of rigging ghetto switches elsewhere. Is it something hard to do? I'd get the switches most likely from the scrapyard.
Please note that I am myself quite clueless (which is why I'm asking for your help) but this will be done with a friend who's a mechanic and has worked quite a lot on Subarus (although not specifically not on offroad light setups).
Thanks!
'Fly
Thanks!
'Fly
