taza
Well I should probably post up here about the Locker project im working on. Many of you know how painful it is to have open or useless viscous lsd's in our Subaru's. 90% of Subarus from the mid 80's onwards use the R160 diff.
Now I didnt really want to pay a few thousand dollars for Cusco or some other for form of LSD. But the downside is that they are only LSD's not even lockers for that price.
I got the idea from Blue Fox who was working with using the rear drum brakes to create seperate leavers for each side and lock the one with the least traction to make the other wheel get the power needed to move the vehicle. From this I had the idea of just creating a locker, whether it be air, electronic or a leaver.
I have good skills at using CAD programs to design objects and buildings. So I am going to try and use my skills along with the help of others to come up with a locker for the R160 differential. I am not a fan of auto/E lockers and I have read that in manual transmission vehicles they jump, bounce and skit around on the roads abit. So if this project comes together it wont be an auto locker.
Another solution is to upgradeto R180 diffs then get a locker for that, but personally I dont want to have to go and change all my diffs around and mess with my gearing. I want to use what I have...
Our vehicles at stock are quite capable for a semi-offroader and with modifications are very capible. But there are moments that im sure most of you have gone 'if I had a locker I wouldnt of been stuck for hours' or "it would of made that hill so easy to climb', situations like that anyway.
Now for this project an engineer would be quite helpful but since one hasnt contacted me im kinda on my own for designing it. I have the support of many people over at AuSubaru and im sure I will here too.
I have acquired 2 R160 open 3.7 rear diffs that i will be picking up in Perth when I go in about 3 weeks time. Once I get them I can see actually how much room there is and start making measurements to come up with a design. I am probably going to have to design a new carrier then the locking mechanism.
Carl has offered to have a go at actually building it since he is a genius at making things out of blocks of steel :biggrin:
I am willing to get something out of this, even if its destroying a diff in the process. Now its not real hard after looking at other designs of lockers but it is going to take time. If anyone is willing to help, be supportive or has anything to comment post it here or give me a pm.
You can also check out the thread where I started it at Ausubaru.
https://www.ausubaru.com/forum/showthread.php?t=19545
Taza
Taza
