taza
I think this is the right spot for this topic.
The past 3 times I have been offroading I have smelt a burning smell. I know its not the clutch as I know what that smells like and havnt burnt it enough to smell it in ages. I can only smell it when im working the car, pushing it hard. Like 3500+rpm. But even if its only for 1 or 2 mins. In the past I have been able to push her through soft sand at 4500rpm for a good 10mins without any issues. The temp guage does not budge nor is there any check engine lights.
Today after work I removed my air filter box and it took me a good 10mins to find the tranny/front diff dip stick :lol: It was covered in sand and grease. The engine bay in now clean but after checking it I found that the oil hasnt been changed in 35,000km (even with all my hard offroading) and it was about 2mm below the Low mark. I almost freaked out. The coolant reserve tank is below the min mark and my engine oil is due for a change.
Tomorrow im changing all three
I plan on putting Shell helix Super 15W-40 in for my engine oil.
I have genuine Subaru coolant. I was thinking a 60\40mix. 60% coolant and 40% distilled water. Does that sound about right? I do live in a hot climate. In summer I get temps upto a good 45c degrees and in winter a absolute minimum of 0-5c degrees. Usually not much lower than 15 or 20c in winter though.
I know absolutely nothing about changing the tranny oil (this will be my first time ever). what oil should I get? Whats a good brand? in the manual it says GL-5 but what about viscosity wise?
My engines an EJ20 N/A
This will also be my first coolant change too but should be ok.
Some advice and recommendations would be excellent. I have learnt a good lesson, always keep up the services especially when you do lots of offroading. It could of turned out bad if I ignored it.
Thanks
Taza
Thanks
Taza
