petercafxt
Guest
Well the mighty XT has just done 97500km approx. It is fitted with Whiteline swaybars front and rear.
After the usual initial problems with the rear swaybar, mounts, welding etc, I haven't had any problems, but now....
The right front bracket on the lower suspension arm has broken off, so it is just a reminder for those of you who have hd swaybars on the front to have a good check.
The car has left the bitumen on only a few short occasions and then at low speed.
Since I am posting, I may as well tell you about the Yokahama Cdrives it put on at about 28000km. They lasted until about 87000km and had to be replaced only because an alignment wasn't done correctly. Great handlers, but noisy and they tramlined.
