Left to their own devices, they should last a fair while. I hate changing turbos- I think I'd rather go to the dentist- almost! You will need some good 14mm flank drive 6pt sockets, a ball joint type uni joint, some long extensions and a good ratchet for underneath. Plus I use a super long 14mm ring spanner for the ones up top. You do the job with it cold, with liberal use of WD40. The hard part is putting it back on, the trick being to get the oil return hose on. If you do it often, you're right. But if like me you rarely do it, you forget the little tricks after a while. Oh, did I mention removing and re-installing the heat shields is also a pain! Depending on the sort of driving you do, you could go up 2 or 3 sizes in turbo- but then you'd have to get bigger fuel pump, injectors and definitely a re-tune. If you are happy with what you have, remember the automotive KISS principal. Keep It Standard Stupid!
