Rally
Some of you may be aware that I have installed a DCCD on my Impreza. Because my car was not equipped from the factory with a DCCD, it has no DCCD controller. The advice I had was to purchase a product from Canada called DCCD Pro to controll the DCCD.
The system gives you the option of auto or manual functions. For now, I'm leaving it on auto. What is interesting for offroad use is that in manual mode, there is an adjustment knob which when turned fully clockwise locks up the centre diff. It means that the car will not turn around corners (say when doing a u-turn) and will let you know with some substantial clunks if you try.
I know when you are on uneven terrain, the standard centre diff can let you down. WIth this set up, at least you will get power going front and rear.
With everything shut down over Christmas, I have been unable to take the car to get the exhaust modified or get a wheel alignment, but in the extremely limited testing I have done, the front and rear diffs (now both helical compared to the previous open front, VLSD rear) seem better able to get power to the ground. Unlike the centre diff, they are not adjustable and do not lock. But while not perfect, I suspect they would do a better job than what is currently on the Forester. When I have tried the car out a bit more, I'll re-assess how the diffs performs.
