subydrift
- Dec 4, 2010
- 4
Hey guys, I just got myself another 97' Outback and am wanting to build some lift spacers for it. I have them all designed in AutoCAD and Solidworks and have templates made from MDF so I know they'll fit but I am just wondering about materials. I want it to be a 1" thick piece of plastic-like material so I can cut it out rough with a jig saw and then clean it up with the template and a table router. Origianlly I was going to use HDPE as it is used in rally cars and is the same material used by other manufacturers for their spacers. But, my work has an abundance of 1" thick clear acrylic sheets that are going to be discarded soon and I was wondering what you guys thought about using this material for the spacers? I am going to try and get the material specs from our local distributor also. Just hoping someone has had experience with this material in high compression applications that can chime in. I'm mostly worried about it cracking either from being under stress or from the cold weather.
Thanks for any insight/tips/advice, etc.
Robbie
Robbie
