joffa
Hi Folks,
My parent's have my MY06 Forester at the moment. On Saturday the battery started to play up and went flat. They called the RACV who got the car started again and suggested a drive to recharge the battery and if it continued to give them issues replace it Monday morning (this morning). So mum went down to the local garage (RACV affiliated) to get the battery replace, which they did.
Having left the garage the subi started to play up at low speed including stalling a few times when turning corners. She took it back to the garage who rang Subaru to speak about the issue. Subaru informed them that the battery can only be replaced by a subaru dealer because the engine idle settings for the ECU need to be reset. Subaru refused to tell the folks at the garage how this was done as they insisted on doing it themselves. The garage guys rang the VACC who said that more and more car companies were doing this sort of thing...
Has anyone else encountered this madness??? If so how do you reset the ECU and idle? 'cos I'd hate to be stuck out in the middle of Aus only to be told by the people art Subaru that it needs to be towed to the nearest Subaru dealer to get the battery replaced...
I'm going to be speaking with Subaru in the morning to try and get the car fixed 'cos at the moment it's not running that well at idle, though a long-ish drive seems to have made things a bit better. Though it's not running properly at idle.
Any help or thoughts would be helpful.
Cheers, Joffa.
Cheers, Joffa.
