Window Noise
  • Thread starter Thread starter tinknocker07
  • Start date Start date
tinknocker07
Guest
My right rear window makes a squeaking noise when I put it up. It is like something is rubbing on the glass:(
Any Ideas on fixing this
Nate
role up the window with the door open this will see if it is the window rubber. if it makes noise it posibley is the center guides. if is the window rubber use a thin cylocone past and rub it into the rubber real well let me know:poke::monkeydance:
I think it it is in the door but I lube up the rubbers :lol: tomorrow to make sure.
Nate
There is a guide about 20cm from the mirror end in the door that could be worn after a while it will scratch the glass:sad: i think it near the top
Jan
Well it is in the door :shake: Now what, do I need to take door all apart replace every thing.
Nate
