Hawkebender
Guest
Can the transmission of a subaru be set-up to run as a rear engine like a Volkswagon Beetle?
... you cant use a subaru transmission unless you want 5 reverse gears. The traditional method of flipping the diff wont work in a sooby. ...
There are kits to actually mount subaru engines to VW transmissions. you cant use a subaru transmission unless you want 5 reverse gears. The traditional method of flipping the diff wont work in a sooby.
