Barry
Running 6B&S wires to camper trailer deepcycle battery
O.K.,
Like Silver (and probably others) I have a camper trailer. I need to run twin 6 B& S (i.e. each conductor 13.5 sq. m.) from the engine compartment to the towing hitch, where it will connect via a 50 amp Anderson Plug to the wiring on the trailer.
These are thick cables, so here are my questions:
1/. Has anyone run similar cables in an Outback?
2/. Where / how did you get it out of the engine bay? [Through a firewall grommet (where?) and into the cabin, OR out of the bottom of the engine bay]
3/. If internal, how / where did you run it inside the car?
4/. If external, did you run it through the sills (and how did you get access to the inside of them?) or
5/. did you run them above above those plastic 'tray' things under the body?
Also interested in any other solutions you may have discovered.:iconwink:
Pictures would be fantastic if anyone has any.
O.K.,
