buttwrx
- Sep 30, 2009
- 13
After reading up on this mod from others helpful links, I have successfully completed the install on a '99 Outback 2.5 auto. A few things differ on my model outback, so i thought i should share my experience.
TCU location: found under the drivers side dash, just left of the steering column, with three wiring plugs (white plug removed).
Wire selection: with help from https://www.subaru-car.ru/leg1/leg1_sec1_11-1.pdf
we determined that our transfer duty solenoid was connector B54 terminal 6 which on our outback was a yellow wire (shown in the centre of the plug which is turned upside down for the photo). Double checking with a voltmeter (when adding removing the FWD fuse from the fusebox) confirmed this.
Finding the correct switch (SPDT on/on) was a challenge. we settled with a Britax (https://www.britaxae.com.au/products.php?categoryname=Rocker&subcategoryid=54&page=5)
This allowed us to mount the switch up beside the fog lights and cruise switches. Some filing was required for fitment.
Resistors, heat sinks and thermal conductive tape were sourced from our local Jaycar with the end result :
Resistor location was found under the dash with a near by bolt/nut used as an earth:
End result:
End result:
