Led lights
picked up some cheap LEDs from ebay like this 9 SMD festoon for US$1.94 delivered. Fitted perfectly with no mods needed. Careful ebaying can save you $$$
In case you're wondering, I also added 24 LED strips on the sides, a pair cost AUD$10 delivered also from ebay
hahaha. i get heaps of good LEDS for nothin as they are cut off's from electrical installs that i do. these are European made too! not chinese garbage. i've had 'em for a while just hadn't had time to install 'em. will post pics when i do:ebiggrin:
2005 Outback rear LED lights.
Has anyone replaced any of their rear lights with LEDs?
In particular the reversing lights. If so what globes did you use?
Also, will coloured LEDs work with clear lenses. EG amber LED if a clear indicator / red LED in a clear stop light?
I sent you a PM
Sorry I missed the links in post #1 My bad:shrug:
Nate
Another Aussie supplier.
Found this googling today.
https://www.brightlightautoparts.com/
Was looking for LED replacements for the '7440' wedge globe. (Outback tail and reversing lights)
Found a link on a Lancer club forum. They were a big rap for this Melb based supplier. Includes free postage - Australia wide - on orders over $150 (from memory). :)
Will check them out on Saturday.
05 Outback rear light LED replacements!
Specific page showing 'T20' style wedge bulbs, as per 05 Outback.
https://www.brightlightautoparts.com/LEDReplacementGlobes.html
Dimension & specification details of red LED bulb - (Tail, Stop & 'Fog' - i.e. replacement for drivers side reversing / 'back-up' light.) ;
https://www.brightlightautoparts.com/files/T2012V18LEDR22.pdf
Ditto for white LED bulb - (Reversing / 'back-up' light.) ;
https://www.brightlightautoparts.com/files/T2012V18LEDW22.pdf
and amber LED bulb - (Indicator bulbs).
https://www.brightlightautoparts.com/files/T2012V18LEDA22.pdf
Achieving rear LED globes on PERMANENT full brightness.
As those who have followed my 'hijacking' of this thread will be aware, I am intending to replace the drivers side reversing light with a red LED, functioning as a FOG light and the passenger side with a white LED, which will remain as a reversing light.
I am using T20 wedge base '7443' globes, which are the equivalent of 'dual filament' (i.e. STOP light) globes.
So that the reversing light will be as bright as possible (now that there is only one) and likewise the Fog light, for obvious reasons, I need to have both set to light up as brightly as possible, as if functioning as a 'stop' light.
Is anyone able to describe / explain to me how to wire so as to have these LED globes always light up at 'stop light' intensity?
