PERTH suspension bushes, where to buy?
robdddd
Perth WA
Hi Guys,
I am in Perth and after 2001 Outback front swing arm bushes, can anyone recomend where to buy them?
The main one at the rear of the arm which is just under the passenger's feet is dead, there is now a metalic clunk when I drop the wheel off a kerb or over a speedbump. Also wobbles slightly when braking.
Is it best to go for standard replacemnt or is there somthing a little stronger, as I currently running a 50mm lift and King Springs.
thanks.
rob
Bought bushes from Pedders and discovered tonight they don't fit, I hate it when this happens.
The rear of the swing arm has a slight taper on the bottom of the stud that the bush bolts on and the original bush has a tapered inner to suit. The new one does not.
They knew it was a 2001 H6, they even said it is different to the 2.5, therfor I don't know what has happened other than wasting time pulling the mount off and putting it back with the worn bush.
Rob,
I have used Wilkinson suspension in Bayswater to fit a lift kit to my car, other club members have used Precise suspension in Wangara.
cheers
Thanks.
Pedders came good with the right part, something wrong with their catalogue for the H6. Just have to find time to install.
