Yogi
The fan speed switch in my '94 L Series Wagon is dodgy. Air only comes from the vents when it is on setting '4' - flat out. I think its most likely the resistor block causing the problem, as when on setting '4' the current by passes the resistors and goes directly to the fan.
Has anyone had the same problem? If so, was the resitor block? Where abouts is it located? Do you have to pull the dash out?
My heater is also playing up. I can't seem to get any hot air to come out of the vents. I have checked the heater pipes from the radiator and they seem to be in place and in good condition. I'm not sure if the problem could be linked but any help or ideas would be appreciated.
Cheers,
Justin
Cheers,
Justin
