blondy
Hiya Guys,
I have a few questions, some...or all may appear stupid to ask...but seeing this is my first modern
car and subaru i thought it best to seek before i go doing something stupid and damage anything.
All questions are in relation to my 2005 Outback 2.5 non turbo, So here it goes;
1) I know this one is in the wrong thread, but was easier to add to this post...It's called a symmetrical AWD and has Hi and Low range. I have searched and searched the manual
and it does not tell you the correct way to use this system. I have driven 4X4's where you have to
lock in the front wheels, be at a stand still and select the correct gear then off you go. But what
is the correct way i should do it with my outback? Is it best to be stationary when changing from
Hi to Low? Or is it safe to change while on the go, and if so, what speeds is it capable to do so?
2) A friend made me aware that some forester's and outbacks in my year and onwards came with a cigarette
lighter in the cargo area/boot and i think i have found the spot that it goes. Is this true and if so,
would the wiring be there if i wanted to put one in? Or would i have to run a new wire from the battery?
which isn't hard, but no point doing it if i don't have too.
3) Switches, i want to add some for some accessories i'm looking at putting in my car. I've noticed there are some
spots for them, i got the blanking plate out. But it seems to be one big solid piece and already has some
wires plugged into the back of it as shown in the images below.
The other one in the centre console area appears to be in there solid, so if i want to use that one,
i'll probably have to do some cutting?
Otherwise, Anyone have any idea's or suggestions on succesful spots they have run switches to? I had the idea
of putting them in the sunglasses holder that's in the roof, but that probably will be alot of work/hassle to try
and run cables up there and ground them for the switches. Else i'll just have to cut my own holes in the current
plastic somewhere? Which i was trying to avoid for the day i want to upgrade and take out some of the components
i put in, don't want to leave ugly holes around the place.
4) Cable Running, any helpful hints are greatly appreciated. I haven't had the time to remove the plastic from under
the Dash yet to find out where the current wires come in.
I think that's the main ones for now, thanks for your help and time to read.
