joffa
Hi Folks,
Been meaning to complete this project for some time. It's a video capture application that works within OZI Explorer (that way I can have the web cam running in the OZI Explorer application on my Tablet PC and not have to switch between it and the video recording app while driving). Figured that I may as well share it with the world.
Requirements:
Microsoft .NET Framework V2.0 or higher
Microsoft DirectX Runtime
I have tested it on Windows XP and Windows 7. When you run it it will automatically start OZI Explorer. It will run in the background and wait for the Moving Map window to be displayed then fit itself in below the Moving Map Control (see attached pic). I've tested it on resolutions down to 1024x600.
If you run it on Win 7 or Vista it does require some acknowledgments for User Access Controls (this is due to the way it integrates with OZI Explorer).
Though fairly functional this is still a work in progress as there are a few things I would like to clean up.
Any feedback would be welcome. I have tested it with my Logitech web cam and it works fine. Should be ok with others too.
You can get it from:
https://members.iinet.net.au/~joffanvetti@ozemail.com.au/OZIVideoCapture/OZIVideoCapture.msi
Cheers,
Joffa.
PS: The work for the DirectX integration was done by Brian Low as a sample and released under the creative commons.
Requirements:
Cheers,
Joffa.
