mav
This installation is for a 2002 subaru outback, i will not accept any responsibility if anything happens to your car as a result of this install
1. I decided to install the uniden Uh400sx uhf radio and antenna, here is my installation.
2. Start by finding the rubber grommet in the engine bay, take this out and get someone to poke a screwdriver through so you can see in the foot well where i comes out, put the antenna cable through and pull out enough cable for where you want to mount the antenna
3. Now start taking the gear knob off and the boot aswell, this will leave you 2 screws that will need to be taken out from where the little tray is.
4. There will be another two screws holding the coin tray in, these need to be taken out so that the fascia suround can come off, once these are out slightly pull at the bottom of the panel and work your way up, be careful because these may be very fragile.
5. After that you will have to take the main unit out there are two screws on the bottom and two either side, a magnetic screwdriver would be the best for this just incase they fall and you cant find them, the main unit should just slide out ofter that.
6. I decide to put mine in the bottom DIN slot cos i didnt buy the DIN surround for the radio, this is prob a good idea to buy it when u get the radio, so i took the bottom DIN slot out but the uhf poked out way to far and would probably hit the gear stick, because it was tapered in i ended up cutting off about 25mm 1inch from the back and it then fitted in fine i used sum cloth tape to hold it in there for now. sorry no pictures for this step.
7. For the power i used the cigarette lighter power cables, i hardly ever use the outlet so i thought id put it to good use, there will be two plugs coming off, one for the power and one for the light power, the one attached to the globe is NOT what you use.
