Just dug out the bit of paper from when I first did mine back in 2006. Copied below verbatim. From memory, I think I had to test and trace all these manually, and the first colour is the body colour of the wire, second colour is the colour of the stripe. Pretty sure (
) this is accurate:
black - negative
blue/brown - positive
yellow/green - accessories on
purple - lights on
white/red - rear left positive
blue/yellow - rear right positive
red/white - rear right negative
white/black - front right negative
blue - front right positive
green - front left negative
brown/white - front left positive
red/black - rear left negative
blue/white - ? *
black/yellow - ?
*This might be power or switch signal to the RF amplifier for the window-mounted antenna, but no guarantees on this (or any of it for that matter!)
Good luck with the install Tony. I certainly prefer the sound of my Clarion over the original deck.
https://offroadsubarus.com/showthread.php?t=975
