Unread 31st May 2018, 08:04 AM
OneSixty's Avatar
OneSixty OneSixty is offline
Year: 2003
Model: SG Forester 2.5X
Transmission: 5 Speed Manual
OneSixty is on a distinguished road
Default OneSixty's $500 SG Forester
Recently purchased a $500 SG Forester. This and the photos may raise a few questions so i'll answer them so you don't have to ask
Q: What is going to happen with the L-Series? A: Cleaning of the L-Series will be finished and then it will be sold.
Q: Why was it so cheap? A: The owner said the clutch wasn't working, now have found out it's just a missing clutch operating fork. Also won't run on it's own fuel and sounds like only 3 cylinders.
Q: Where is the airbox? A: The owner had taken the airbox off to inspect the clutch.
and it has been washed since the photos were taken
Here are some links to the photos:
Night time pick-up: https://cdn.discordapp.com/attachmen...7120/image.jpg
Front: https://cdn.discordapp.com/attachmen...4491/image.jpg
Rear: https://cdn.discordapp.com/attachmen...4187/image.jpg
Driver Inside: https://cdn.discordapp.com/attachmen...9115/image.jpg
Inside Rear: https://cdn.discordapp.com/attachmen...5505/image.jpg
Engine bay: https://cdn.discordapp.com/attachmen...6970/image.jpg
Kilometers: https://cdn.discordapp.com/attachmen...9328/image.jpg
Unread 31st May 2018, 08:08 AM
He took the airbox off to inspect the clutch? Did he open the boot to check the radiator as well???
Unread 31st May 2018, 08:43 AM
OneSixty's Avatar
Year: 2003
He took the airbox off to inspect the slave cylinder/push rod that operates the clutch release arm.
Unread 31st May 2018, 09:17 AM
At least it's not as dirty.
Mind you, I guess you've still got to clean the other one up.
Unread 31st May 2018, 10:30 PM
bargain!
Unread 1st June 2018, 04:43 AM
OneSixty's Avatar
Year: 2003
Here's another reason it was cheap
Sent from my iPhone using Tapatalk
Why have a "real" 4wd when you can have a real AWD
Unread 15th July 2018, 10:45 PM
OneSixty's Avatar
Year: 2003
Figured out why it's not running
Unread 16th July 2018, 01:54 AM
New fuel tank time, unless you are super keen
Unread 16th July 2018, 10:05 AM
W.the.f is up with that tank?? Did they mix the petrol with dirt?
I don't understand how it doesn't have a clutch fork... Who installs a gearbox or engine without the clutch fork fitted? Rookie mistake if it's actually missing.
My L was a $500 bargain. Turned out it needed an engine rebuild. I hope an expense like this doesn't happen with your purchase!
Unread 16th July 2018, 10:35 AM
that's almost as bad a state as the sunroof frame on my SVX!
