Go Back   OFFROADSUBARUS.COM > General Forums > Member Mishaps
Unread 10th June 2019, 07:20 PM
Brandontw Brandontw is offline
Model: Forester X
Brandontw is on a distinguished road
Default Ouch.
Might have gone too far this time. Was trying a pretty steep uphill section that was pretty rutted out with rocks.
Tried to keep enough speed to make it up the hill while straddling the rut and avoiding the rocks. Didn't work out. Fell in the rut hard and beat up my exhaust system pretty good.
The heat shield was rubbing on the driveline all the way home. It is now removed.
Still looks I might have caused other damage. Seem to have some binding/shuddering feeling when accelerating the car out of tight turns from a stop. Something driveline related perhaps?
Seems to run and drive fine otherwise, so i think i'll keep driving it while i investigate, but not quite sure...
Unread 10th June 2019, 07:58 PM
ABFoz ABFoz is offline
Model: Forester XS
On the transmission cross-member, there should be a bolt that moves freely with the exhaust system. I can't find a photo yet but it is connected to a plate with rubber on it. It's designed to stop the drivetrain/exhaust from flexing to oblivion. If it is not centred, it may cause some vibrations when accelerating. Cheers.
Unread 10th June 2019, 09:39 PM
ouch - is that a resonator or the cat that you've munted?
Unread 10th June 2019, 10:20 PM
Model: Forester X
i believe its just the resonator luckily. that picture came out pretty low-res didnt it?
Unread 10th June 2019, 10:22 PM
Model: Forester X
that sounds like a nice easy fix... i'll try to have a look next time im under there. If you find a pic for reference that would be awesome!
Unread 11th June 2019, 01:17 AM
Model: Forester XS
Yes, check number 4 on the photo below:
That metal and rubber crown connected to the transmission mount is not supposed to be touching the cross-member but it is designed to prevent the transmission and drivetrain from overflexing. Check if the bolt is somewhat touching the cross-member as it may give some unnecessary vibration. Cheers.
Unread 11th June 2019, 11:31 AM
Model: Forester X
Perfect! Thank you very much.
I'm going to get it back up on stands tonight and investigate some more. I wanted to check the tranny mount anyway and make sure its not broken or overly worn.
Unread 11th June 2019, 11:54 AM
Model: Forester X
Looks like the manual only has two bolts and no center/ stopper?
https://parts.subaru.com/p/Subaru_20...1022AC180.html
i guess i'll find out tonight...
Unread 12th June 2019, 10:39 AM
That's a decent hit!
Unread 12th June 2019, 02:11 PM
Model: Forester X
Indeed! From the looks of it, it would have been bad even with a couple inches more of clearance.
I got under there last night and poked around a bit more. The carrier bearing definitely looks pretty smooshed. Might throw a used driveshaft in there and see if it improves. Can be had from a junkyard for 100$-150$. Probably worth a shot before I pay a shop that much just to tell me that maybe I should replace it.
