  #71
Unread 24th June 2018, 11:27 AM
scalman scalman is online now
Year: 2001
Transmission: 4eat
Removing sway bars give you free extra suspension travel .
Still have SLS in rear on my 2001 outback. Its still works ok.
About travel in front i looked at it simple way. As i removed sway bar in front i thought ok how much my arm with cv axle and steering can go down until it reaches limit pf some kind and as i unbolted top mounts my strut dropped another 5 cm or so. So could that be true that front could have travel of extra 10cm just with longer struts / coils. Because i allready have 5.2 cm strut spacers so it could go maybe even extra 11cm in front.
Is there really no way we could find struts that mount similar from other car that could be 5-10 cm longer so it would give us that extra travel.?
Then again one car pass it with lots of travel and other like fory turbo without any mods could pass itbjust with that power.
  #72
Unread 24th June 2018, 07:37 PM
NachaLuva's Avatar
scalman I seem to remember that EUDM front struts didn't have as much travel as AUDM, can't remember for which models. That would be something to look at
  #73
Unread 24th June 2018, 07:43 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
Interresting ! As far as I am aware, its the exact opposite, EUDM front struts have more travel, at least on the Forester !
Subversive...
  #74
Unread 25th June 2018, 12:00 AM
Year: 2001
Transmission: 4eat
But if you replacing them for kybs they all same yes? Eudm and audm. We here just call them eu or us. And didint heard that on outback they would be diff. For foresters thats true . ones are softer springs and others harder so if you mix up one spring with othet shock you get stiffer strut . just to get those us struts here is problem. But didint heard that people would do that on outbacks. Some say h6 have kinda stronger spring in front vs h4 for that bigger engine but in scrapyards they sell all springs same h4 or h6 . so it might be not true.
For ob there is strangely diff specs that noone properly explain like why 3rd gen outback gc is 8.4' and turbo have 8.7' what they use to get more clearance there. Then again some say 2nd gen kyb struts are better for 3rd gens. But oem dampers 3rd gen works worse then 2nd gen.
  #75
Unread 25th June 2018, 06:23 AM
Ben Up North's Avatar
Ben Up North Ben Up North is online now
can only hope to improve
Year: 2004 | 1992
Transmission: 5MT D/R | 4EAT
I replaced my struts with Pedders. Seem ok. <shrugs>
  #76
Unread 25th June 2018, 07:10 AM
Year: 2001
Transmission: 4eat
Just ok ? So what changed when you changed to them? Handling changed? Some ppl put them here too.
  #77
Unread 25th June 2018, 08:11 PM
Year: 2004 | 1992
The right shocker was cactus, now it's not.
I don't push my car at all, so handling wise I haven't noticed anything dramatic. more noticable off road, the car doesn't clunk on bumps anymore, apart from the worn linkages on the swaybar.
  #78
Unread 25th June 2018, 08:29 PM
NachaLuva's Avatar
I'm using aftermarket KYB struts on the front, this is my 2nd set. And Gabriel struts on the rear, very impressed with these. Seem to have the same or similar valving to KYB, maybe a little softer, and are very strong. On our big outback trip, where I was so badly overloaded that the rear sagged about 4" despite HD raised springs, they held up to the abuse very well. Including several times when I bottomed out hard
2nd gen (BG Outback) is totally different to 3rd gen (BH Outback) & can't be swapped
  #79
Unread 26th June 2018, 05:38 AM
Year: 2001
Transmission: 4eat
2nd gen outback i call is BE /BH and BG is 1st gen. i mean my outback is 2nd gen as most call it . i know why you think differently.
  #80
Unread 6th December 2018, 08:54 PM
Year: 2013 / 2008
Transmission: 5EAT
I never had issues with the stock struts over 70,000 miles of being pushed as much as any. But I do think I got shock fade a few times after long drives on rocky roads.
I put Excel Gs on the Tribeca. The stock shocks lasted 140,000+ miles.
The aftermarket KYBs were said to be firmer than the OEM KYBs on the TB forum. I have to agree. But we are also on performance tires that are nearing the end of their useful life so we will see once we replace with probably a touring style tire.
The little brand that can.
18 4R TRDOP, 08 Tribeca
(13H6OB 2" SLOz, 06 B9)
