  #21
Unread 14th August 2008, 09:02 AM
spinners's Avatar
spinners spinners is offline
Moderator
spinners is on a distinguished road
Gents, please. Looks like everyone has gone to their corners. Lets keep it that way.
Regards,
Carlo
"Improvise, Adapt & Overcome"
  #22
Unread 14th August 2008, 09:14 AM
ian059 ian059 is offline
ian059 is on a distinguished road
Very sorry to hear about your work worries. Work can be hard enough sometimes without personal conflict added to the mix. You and Eastie are quite right, my research was flawed and incomplete. The self-levelling suspension was not discontinued. My Daughters '99 forester had the self-levelling suspension fail on one side of her car and had to replace both rear struts. The guy we bought the new struts from bagged the self-levelling suspension from his long experience with Subaru's.
Hear say, I know, but that's what influenced my opinion. That's all it ever was, my opinion.
  #23
Unread 14th August 2008, 09:33 AM
It's all cool Carlo.
  #24
Unread 14th August 2008, 09:14 PM
Eastie Eastie is offline
Eastie is on a distinguished road
Thumbs up
Never thought about that but I can see the reasoning. Cheers Ian
  #25
Unread 15th August 2008, 05:00 AM
I too had heard that the older SL suspension was suspect and was interested to see how mine would go on the Foz. Well, originally I thought it was just fine and then I heard of one failing in the SG series - well I thought, one was not enough proof, then two - well still not proof. Then in 2005 my LHS failed on Cape York. Most seem to be the LHS as well.
So, why swap - well at least with conventional and especially with heavy duty springs and standard struts the rear won't sag if a strut fails - this could be very important when you are outback and loaded to the hilt with camping gear!
MY'97 Outback RIP
  #26
Unread 15th August 2008, 08:34 AM
Dalez Dalez is offline
Dalez is on a distinguished road
Kevin, you make a fair point about when it can be prudent to go simple. I had already made the decision to change mine for my forthcoming trip - but my primary reason had been for what I hope will be better durability of the KYBs and it being simpler to lift. I now have another reason. However when the trip is over I might swap back to the SLS as it is softer.
  #27
Unread 16th August 2008, 10:33 AM
Interesting. It was the left side that failed on my Daughter Fozzie as well!
  #28
Unread 17th August 2008, 12:40 AM
^ yes, a definite pattern has emerged for sure!
MY'97 Outback RIP
  #29
Unread 17th August 2008, 12:42 AM
subyroo's Avatar
subyroo subyroo is offline
Senior Member
subyroo is on a distinguished road
Can anybody give me an idea of what price I'd be looking at for the following:
Front Only?
Rear Only?
All Round?
Peter
2016 Honda CR-V
  #30
Unread 17th August 2008, 05:15 AM
eden's Avatar
eden eden is offline
bush bash'n ranga
eden is on a distinguished road
Front Only?
Rear Only?
All Round?
ok. i just rang the two shops mentioned by Mr Turbo and Spinners, wholesale suspenion at Penrith quoted $995 for 4 corners fitted.
wholesale suspenion at Black Town $795 4 corners fitted.
pays to shop around!
and i havent finnished shopping yet!
cheers, Eden
2000 outback, subX bullbar + sumpguard,50mm raised strut blocks,30mm raised springs,215/65/16 rubber,uhf, dual battery system,150W spots,touchscreen navigation with oziexplorer. more to come
