Go Back   OFFROADSUBARUS.COM > Trading Post > Private For Sale Classifieds
Unread 25th November 2017, 02:05 PM
LiftedWRX LiftedWRX is offline
LiftedWRX is on a distinguished road
Cool Garage Sale - WRX, STi, LGT, FXT, etc...
Mostly GD WRX & STi parts but some 04 FXT & 05 LGT parts
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
*Links to albums of individual pictures of each part are located beside each group*
04 FXT Pics: https://imgur.com/a/CM4Qgsf
• TMIC splitter $20
• 6 Disc $25
• ACT 6 puck & pressure plate $150
• ACT lightweight flywheel $100
• Driveshaft $50
• Rear Axles $50 each
• Control Arms $50
• Sway Bars $25
• Front sway bar mounts $10
• Rear sway bar mounts $10
• Blown 5 speed - I think it was 3rd gear again make offer
05 LGT Pics: https://imgur.com/a/gQPn9Vq
• Intake manifold $50
• Engine harness $50
• Throttle body $40
• Side feed TGVs $80
• Side feed fuel lines $50
• Turbo inlet $15
• Gauges auto $75
• ECU auto #22611AJ18B $100
• MAF #22680AA31A $35
• BPV hose $5
• Airbox lid $5
• Intake pressure sensor #22012AA160 $5
• Purge valve $10
• Purge valve solenoid $15
• Boost solenoid controller $25
• 04-09 Legacy all weather subaru mats $40
GD WRX & STi Parts
Engine & Drivetrain Pics: https://imgur.com/a/xYSVkuV
• 5x114 Knuckles $400
• EJ20 valve covers $40 set
• STi front axle without outer CV $30
• STi clutch master $40
• STi side feed fuel rails with line $50 set
• STi passenger side feed fuel rail with line $25
• Side feed TGVs $80 set
• Purge valve $10
• STi proportioning valve $20
• BPV with crush mod no elbow $25
• WRX STi blow off valve adapter for FMIC $30 (new)
• Boost solenoid controller bracket $5
• Radiator mounts $10 set (3 available)
• Power steering reservoir $20 (2 available)
• Power steering reservoir bracket #34633FE001 $5
• 04 WRX steering column with ignition & key $75
• 04 STi steering column with ignition, key $100
• 06 STi steering column with ignition, key $100
• Pull type clutch fork pin (5 or 6 speed) $20
• Transmission mount $20
• AC condenser $40 (2 available)
• STi passenger radiator fan $25
• Coolant overflow tank $10
• Starter $50
• Radiator coolant hard line $10 (2 available)
• Manifold coolant hard line $10 (2 available)
• Oil dipstick $10 (2 available)
• TMIC hard lines $10
• Oil cap $5
• Oil cap with fill neck $10
• 02-05 WRX cruise control actuator module $20
• Hood prop $5 (2 available)
• Battery tray $5
• Turbo uppipe bracket $5
• Pitch Stop Mount $10
• Timing Covers: center and right side available $10 each
• Front O2 sensor plastic cover $5
• AC Lines $25+
Suspension & Brakes Pics: https://imgur.com/a/1Ms6AE1
• WRX STi ABS module #27534FE270 $40
• ABS Sensors: #27540AE000 & #27540AE001$10
• 5x114 rotors were turned and never used $50
• WRX rear calipers $60
Exterior Pics: https://imgur.com/a/o4gYp1I
• BBS center cap $25
• Driver rear exterior door handle PSM *$20
• Wiper arms $30 (2 sets available)
• Passenger mirror CGM $25
• Driver mirror no cover black $25
• Passenger mirror no cover black $25
• Gas lid PSM $10
• Exterior B pillar molding $15 each
• Doors $150 each except for rear passenger is $100 because no glass (driver front sold)
Interior Pics: https://imgur.com/a/G7vOkeh
• Visor clips $5 set
• Center rear view mirror sun visor $10
• Interior mirror cover right #94251FE000 $5
• Interior upper B pillar trim $10 each
• Interior lower B pillar trim $10 each
• Interior C pillar trim $10 each
• Rear seat trim $10 each
• Trunk latch trim $10
• Door kick molding trim $10 each
• Driver center console side cover $10
• Rear heat vents $10
• Seat belts: passenger front and all rear available*$40 each
• Seat belt buckles $10 each
• Trunk release cable $10
• Gas lid release cable $10
• WRX trunk hinges and torsion bars $20
• Weatherstripping: Doors, hood and trunk avaiable $5 each
• Fuel pump cover $5
• Jack $5 (2 available)
• Tool kit #97010FE040 $10
• Driver Trunk Side $20 (no jack cover)
• Rear dash $40
• Bugeye door cards $50
• Bugeye front seats $50
• Bugeye rear seats $50
• Blue STi door cards $100
• Blue STi rear seats $100
Electronics Pics: https://imgur.com/a/QuPpVtK
• Headlight leveling switch $10 (2 available)
• 05-07 mirror switch $10
• 02-04 mirror switch $10
• Hazard switch $10
• Engine bay fuse box $25
• Rear view mirror wire cover $5
• Map light $20
• Dome light $20
• 05 STi ignition with 2 keys $50
• 04 STi ignition, key $40
• 06 STi ignition, key $40
• Keyless remotes: 04 STi, 05 STi x2, 06 STi, 06 WRX, 05 LGT $20 each
• Headlight/blinker switch $25
• Wiper switch $25
• OEM horns $5 (2 available)
• ECU cover $10
• Wiper motor $40
• Positive battery terminal cable $5
• 04/05 WRX fuel tank wiring $20
• DRL module #84067FE060 $10
• DRL module #84067fe000 $10
• 04/05 control unit air bag #98221FE110 $40 (2 available)
• 06/07 control unit air bag #98221FE220 $40
• WRX STI left front air bag sensor #98231FE070 $10 (2 available)
• WRX STI right front air bag sensor #98231FE060 $10 (2 available)
• WRX STI left side airbag sensor #98235FE150 $10 (2 available)
• WRX STI right side airbag sensor #98235FE140 $10 (2 available)
• WRX STI left side airbag sensor #98231FE010 $10
• WRX STI right side airbag sensor #98231FE000 $10
• Airbag harness $25
• WRX STI G Sensor ABS #27540FA022 $10
• WRX STI G Sensor ABS #27540FE090 $10
• Fuel injector resistor module #684227 $10 (2 available)
• Door ajar sensors $20 set of 4 (2 sets available)
• 04/05 WRX STi keyless entry module #88035FE140 $20
• 04/05 WRX STi keyless entry module #88035FE141 $20
• 06/07 WRX STi keyless entry module #88035FE190 $20
• 04/05 WRX STi integrated control module #88281FE160 $20
• 06/07 WRX STi integrated control module #88281FE340 $20
• WRX STI clarion antenna amplifier assembly #86327FE090 $20
bump
Unread 25th November 2017, 02:06 PM
bump
Unread 6th December 2017, 08:00 PM
Fixed the size of the pictures
Unread 6th December 2017, 08:02 PM
much better! thanks
Unread 8th December 2017, 02:30 PM
thanks to you for the tip!
Unread 5th April 2018, 09:16 PM
OP updated: lowered some prices and added some new parts
Unread 15th June 2018, 03:24 PM
OP updated with a ton of parts and added a link to new pictures of individual parts after the list
Unread 17th June 2018, 11:15 PM
Updated the first couple of posts with new pictures and parts list.
Links to albums of more pictures are located beside each group of parts
Unread 19th August 2018, 01:28 PM
bump..
