Unread 1st May 2017, 05:27 AM
turbo1600 turbo1600 is offline
Model: outback
Transmission: auto
turbo1600 is on a distinguished road
Default coolant temp and crank sensor wiring colors . ?
hi, managed to completely pull out and break the wires goin to the coolant and crank angle sensors on my 1998 outback 2.5 dohc........
i`ve looked around and i could only find referance to a orange and blue wire and white an blue wire etc...
but non of these colors match my wiring,.
the coolant wire colors are black and black with a yellow ? ( or white ) stripe , these wires still have the terminals on them, but have pulled out the plug.
and the crank angle wire colors are black and white . ( i`ve done a repair on these wires.)
does anybody know which colored wires go where on both of the plugs ?
thanks,...
Unread 1st May 2017, 06:44 AM
Are you sure the coolant sensor only has 2 wires going to it? The crank angle wires go to the ECU.
SG turbo, 99 WRX, PX2 Ranger
Unread 1st May 2017, 06:51 AM
Model: outback
Transmission: auto
hi, yes if definately has only 2 wires goin to it. i know that some may possibly have 3 .
i know the crank angle wires go to the ecu.
BUT i need to know where the colored wires go into each plug .
Unread 1st May 2017, 06:59 AM
I don't think it matters if there are only 2 wires for the crank angle sensor. I believe, but not 100% certain, they can go either way
Unread 1st May 2017, 08:38 AM
Welcome aboard t1600.
Unfortunately can't help with positioning of the wires within the plug from my old Haynes manual (but I did confirm the number of wires and colour).
Unread 1st May 2017, 01:21 PM
Thinking more about this, the Coolant temp sensor is a thermistor (temp sensitive resistor) so I believe the current can flow in either direction. Resistors do not have polarity so shouldn't matter which way the wires are connected.
Unread 1st May 2017, 09:00 PM
Turbo,
doesn't sound right. Coolant is grounded to the block and one-wire in.
Hard to see - but that second picture, the dirty white/clear plug looks like coolant to me, and matches with the single spade connector sticking out.
Easiest way to be sure, if you have a wiring diagram, is to trace back to the first plug, or the SMJ.
Unread 1st May 2017, 09:21 PM
Ah ok - there are two sensors.
Single wire for the gauge, 3-wire for the ECU (the brown socket)
The wiring diagram I have (which is 1998+ AUDM BE/BH. But you say 1998 DOHC, which makes me suspect you've got a late BG), says plug E8 is triangular, light grey.
Pins 1-2-3 clockwise from top left. Point of triangle down.
1 - BY
2 - WG
3 - BR
Crank sensor is Yellow (pin 1) and Orange.
Cam sensor is Black (pin 1) and White -- sure you're not confusing the two?
Dunno if any of that helps..
Unread 1st May 2017, 09:23 PM
Model: outback
Transmission: auto
Originally Posted by duncanm View Post
Turbo,
right , the sensor for the temperature gauge is a SINGLE wire sensor.this sends signal to the gauge ONLY.
the coolant sensor is for the ecu and is a two wire one. and this only sends temp info to the ecu only.
Unread 1st May 2017, 09:30 PM
Just to distinguish between the two, I believe the one for the temp gauge is called a "sender" and the one for the ECU is called a "sensor".
