Unread 12th July 2019, 06:22 AM
Austas75 Austas75 is offline
Year: 1999
Model: SF Forester
Transmission: 5spd Manual
Austas75 is on a distinguished road
Default SF Forester larger diameter exhaust
Not sure if this is in the right section?
But I am looking at replacing my exhaust and was toying with putting one on with a larger diameter has anyone done this and was there any performance gains?
Unread 12th July 2019, 07:20 PM
I have a modified exhaust system; can't remember the diameter but it's a little larger. You don't want it to be too big as the engine relies on back pressure. I have aftermarket free flowing cat and resonator and I think they would make more difference than any increase in the pipework. Performance gain - possibly but hard to gauge unless it was dynoed before and after.
Unread 13th July 2019, 07:13 AM
Year: 1999
Model: SF Forester
Ok Thanks, Kevin, I just want a little extra power to help with towing. I will look into a free flow cat and resonator.
Unread 13th July 2019, 02:55 PM
If your SF is non-turbo, it won't help.
But you can go into low range even on road, that helps alot as you have a 1,447:1 ratio.
Another option is to fit an EJ22 if you have an EJ20/122hp engine or an EJ25 if you have an EJ20/125hp engine because of harness compatibility.
Unread 13th July 2019, 09:00 PM
@Austas75 BTW - I only replaced the exhaust system because it needed replacing. If your exhaust is in good condition then I wouldn't bother.
