Go Back   OFFROADSUBARUS.COM > Technical Forums > Engine Management, Tuning and Datalogging
Unread 12th June 2019, 01:31 PM
Default ECU software modification
Originally Posted by Beachworm View Post
Perhaps it would help to know that I have had the ECU software modified to perform better off road. This affects the front/rear split and the responsiveness of the VDC. In effect it has given me X Mode without the hill descent control. I have not experienced the problems you mentioned and I have climbed some impressive hills on rock/gravel/clay mixed surfaces. As long as traction control is switched off, my tweaked VDC performs above expectations.
Sounds like a great mod!
Unread 30th June 2019, 07:54 AM
temmah temmah is offline
Year: 2016
temmah is on a distinguished road
@Beachworm, where did you get this mod done?
2016 Forester 2.5L CVT - SubaXtreme Bash Plate
Unread 30th June 2019, 06:12 PM
that mod would be amazing to have. i allways thought why not making some chip like or smt for those VDC so that you could mod them to grip more or let spin wheels more etc... would be amazing.
Unread 30th June 2019, 06:49 PM
Throttle Happy Tuning (Check their page on Facebook)
The guy who runs the business is Matt. He is based in Coffs Harbour NSW but travels around various places. He came to Brisbane for mine to be done and had several other customers waiting while I was there.
Unread 2nd July 2019, 11:23 AM
so he reprogram VDC ecu or what he did with it ? used computer or what ?
Unread 2nd July 2019, 08:01 PM
He plugged his laptop into the OBD2 port. I started the engine and he modified the ECU parameters (this took about 10 minutes) During this time I had to stop and start the engine a number of times. I then drove the car, stopping, braking and accelerating as instructed while he made more adjustments. (this took about another 10 minutes).
Unread 3rd July 2019, 06:50 AM
So its permanent changes? . Got it. And its only works on newer models i guess yes? Maybe someday someone will share how to do it or what software to use so more people could do it.
Unread 3rd July 2019, 07:18 AM
Tweaksta's Avatar
Tweaksta Tweaksta is offline
Year: 2000
Do some searching on RomRaider. That might be able to do what you're looking for.
Unread 3rd July 2019, 08:12 AM
Romraider can acess vdc ecu and tweak it?
Would be amazing to separate TC from vdc so it wouldnt kill engine power.
Unread 3rd July 2019, 07:49 PM
It works on any ECU/TCU that isn't locked. Matt is a top engine tuner & can do this on all Subarus except the very early ones, unfortunately not my 97 Forester
CAUTION: Only use a reputable engine tuner with proven experience on your particular model and mods. Changing the tuning parameters can quickly blow the engine if not done right. The engine needs to be retuned if changes are made to the exhaust, intake, turbo, injectors, etc
Done properly, you get more usable torque with a better torque curve, better fuel economy, better reliability (ECU), no torque limiting in 1st gear, better shifting (auto) and better VDC
