Scubaru Technologies
Scubaru Tech
Product Developer
California
WRX
Manual
Hello everyone have you ever noticed that there are no bolt on snorkel kits for Subarus of any kind. We here at Scubaru Technologies noticed that and would like to change that. We are in the process of building a snorkel kit specifically for Subaru, the hard part is which one. We couldn't decide so we figure it was best to ask. What models and years of Subarus do you want to see a kit specifically made for, let us know. Thanks
Ben Up North
can only hope to improve
FNQ
2004 | 1992
SG Forester X MY05 | 92 SVX
5MT D/R | 4EAT
Any years that stand out to more then others ?
The SG has the reputation of being the most off-roady in standard form.
And as they're an older model people aren't generally so worried about chopping them up.
There does seem to be a bit of a thing in the US with the Crosstrek/XV being modded for offroad so that might be worth looking at too.
Scubaru Tech
Product Developer
California
WRX
Manual
Thanks for the input it's looking like the forester is the favorite anymore input from everyone ?
Kevin
Sydney, Oz
MY'03
A/T
[MENTION=16372]Scubaru Tech[/MENTION] I also think the Forester is the best candidate as most other Subies have poorer approach and departure angles (unless modified). I would also develop for later models like SH and SJ as I imagine most earlier model owners, like me, would have already found a solution of their own if thought to be really necessary.
Just my 2 cents
NachaLuva
Product Developer
SE Melbourne
I'm a lift kit manufacturer so I might have some insight into which models are modded for offroad the most
I sell probably twice as many SG Forester kits as the next closest which is the SH Forester
If you're only going to do one shape, I suggest doing one that fits well on all models even if it isn't perfect on any. You'll find that most are very similar, with the later models having a more raked back windscreen than earlier models. So if you do one with a lower raked upright, it will fit both
Atm there are several snorkels that fit earlier models like the SG (some bending required with a heat gun) but none that fit the later models too well. This would be the market I would target as it's the most rapidly growing, & a late model snorkel will fit an early model but not vice versa (if done right)
Beachworm
Brisbane Australia
Forester X Luxury, sump guard, bigger AT tyres and 50mm Subieliftoz lift, breather extensions
Auto
I've fitted a Suzuki Vitara snorkel to my SH Forester and it wasn't all that difficult. I think it looks reasonable. The issue that needs to be addressed by any manufacturer is the air filter box. It's a waste of time fitting a snorkel if the OEM air filter box is retained without serious modification to ensure it is water tight. I gave up trying to use it and opted for a cheap filter box and filter from Aliexpress until I can find a fully sealed unit that uses the OEM filter.
The snorkel I bought came with a length of flexible hose and hose clips. These should be included in any kit that goes to market for Subaru.
scalman
Lithuania
2006 3.0R 5EAT Sportshift VDC/VTD LPG
5eat Sportshift
can you just make OEM air box water proof with some kind of sealants and stuff ? it doesnt need to be underwater selaed just some water proof does it ?
imnathanturner
New Member
Lithgow
forester
manual
thats all I've ever done. pipes joined up, sealant from outside, sit at about 2k revs for a minute or two to pull sealant into any gaps (using the vacuum)
Kevin
Sydney, Oz
MY'03
A/T
Won't work for early SG as the snorkus box is badly designed and can suck water straight across the top and into the air filter.
