2004 WRX Part Out - JDM EJ20X, Invidia, GReddy, Perrin, Grimmspeed, SPT and STi parts
LiftedWRX
WV
2004 WRX Part Out 86k miles
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine & Drivetrain
JDM EJ20X Longblock (less than 60k miles) $1,500
PE1820 Turbo - Upgraded VF30 $700
05 FXT 5 Speed Transmission 4.44 $750
05 FXT Rear Differential 4.44 $200
FXT Intake Manifold $100
FXT DBW Throttle Body with MAP $100
FXT Side Feed TGVs $75
STi 555cc Yellow Side Feed Injectors $100
Side Feed Fuel Rails $50
DW300 Fuel Pump $75
Fuel Pump Hanger $75
Fuel Pump Controller $50
04 STi Engine Harness $100
04 STi Bulkhead Harness $200
04 STi Cluster Harness $50
04 STi ECU #8J 22611AJ241 $200
Coilpacks #FK1086 $50 each
MAF Sensor #22680AA310 $25
04 STi Clutch & Brake Pedal Assembly $75
04 STi DBW Gas Pedal #36010FE020 $50
Catless Aftermarket Uppipe $100
Axles $100
Driveshaft $100
Engine Crossmember $150
Transmission Crossmember $100
Rear Differential "T" Crossmember $100
Alternator $100
Power Steering Lines $50
Power Steering Reservoir $25
Power Steering Pump Bracket $15
Steering Rack $125
AC Compressor $100
AC Compressor Bracket $15
AC Lines $25+
AC Tensioner $30
AC Condenser $50
Washer Fluid Tank $20
Coolant Expansion Tank $50
Radiator Fans $25 each
Clutch Master Cylinder $35
Clutch Slave Cylinder $30
Clutch Fork $20
Clutch Fork Rod $20
Clutch Line OEM $15
Clutch Line New Stainless Steel $20
Pitch Stop $20
Wiper Motor $40
Wiper Linkage $30
Fuse Box #82231FE010 $20
EBCS OEM #16102AA360 $25
Rear O2 Sensor #22690AA520 $35
TMIC Brackets $20 each
Battery Tie Down with Hardware $20
Battery Power & Ground Cables $10
Horns $10 set
Timing Covers $10 each
Rear Crossmember SOLD
Purge Valve SOLD
Purge Solenoid SOLD
Charcoal Canister SOLD
STi TMIC with Y Pipe SOLD
STI BPV with Hose SOLD
SPT Intake with Heatshield SOLD
GReddy Evo 2 Cat Back Exhaust SOLD
Perrin Inlet SOLD
Invidia Catless Downpipe SOLD
Grimmspeeed Hood Struts SOLD
Oil Catch Can with Lines SOLD
Front "U" Subframe SOLD
Exedy Clutch & Pressure Plate SOLD
Flywheel SOLD
Power Steering Pump SOLD
Exhaust Manifold SOLD
GMS Radiator SOLD
Suspension, Wheels, Tires & Brakes
Rota Gforce 17x8 +48 Wheels with 225/45 General Altimax Artic Tires $800
Struts & Springs $300
Front Knuckles $100
Sway bars $25
Rear Aftermarket Endlinks $25
Front Aftermarket Endlinks $25
Trailing Arms with Brackets $40
Front Calipers $75
Front Rotors $25
Rear Rotors $25
ABS Sensors $25
Brake Master Cylinder $25
Brake Booster $50
STi Aluminum Control Arms SOLD
Lateral Links SOLD
ABS Module SOLD
Stainless Steel Brake Lines SOLD
Proportioning Valve SOLD
Rear Calipers SOLD
Rear Knuckles SOLD
Exterior
Headlights HID Retrofit Plug N Play $300
Taillights $250
Hood $250
Front Bumper $250
Front Bumper Beam $100
Rear Bumper $250
Rear Bumper Beam $100
Trunk with Wing $200
Side Skirts $125
Grille $50
Gas Lid $20
Wiper Arms $30
Trim & Weather Stripping $10+
Headlight Brackets $20
STi Scoop SOLD
STi Intercooler Splitter SOLD
Mirrors SOLD
Doors SOLD (have some other GD rear doors)
Fenders SOLD
Chassis SOLD
Interior
Front Seats $400
Rear Seats $200
Door Cards $50 each
Carpet $100
Dash $100
Center Console w/STi Shifter Surround $125
Gauge Cluster 86k Miles $100
Cluster Surround $20
04 & 05 FXT Steering Wheels with Airbag and Cruise Switch $100 each
Steering Column $100
Steering Knuckle Linkage U-Joint $40
Clock Spring #83116SA010 $50
Ignition with STi Key & Light $75
HVAC Controls $40
Radio & HVAC Surround Trim $20
Center Air Vents with Hazard Switch $30
Headlight Switch $25
Wiper Switch $25
Fog Light Switch $10
Hazard Switch $10
Cruise Switch $10
Mirror Switch $15
Master Switch $35
Passenger Window Switch $10
Door Handles $10
Passenger Airbag $50
Delrin Black Teardrop Shift Knob $25
E-Brake Handle $30
Kenwood 4 Channel Amp #KAC-8402 $50
4x 6 3/4" Kenwood Speakers #KFC-P709PS $80
Auto Dimming Rear View Mirror $40
Map Light $25
Dome Light $20
3rd Brake Light $20
Visors $50
2 Button Key Fob Remote #88036AE060 $20
Subaru Tool Kit #97010FE040 $20
Kartboy Shifter SOLD
Glovebox SOLD
Clock & Trim SOLD
2004 STi Gauge Cluster 98k Miles SOLD
Weathertech Floor Mats SOLD
Alpine Head Unit Bluetooth #CDE - HD149BT SOLD
Cup Holder SOLD
