PigSti
Guest
Bad fuel stink on cold mornings!
Blue Fox, you have done this fix! Your thoughts?
Any help is greatly appreciated but this post is for me as I collect links and info for a one stop reference when I finally have to fix this myself!
Damn car is stinking of fuel on cold mornings. So the fuel rail rubber hose parts must be hardening up and the hose clamps are loosening. Been looking at some sites for tips but I'm sure Subaru released an updated fuel rail part set for the SG to correct it! Anyone know of it?
[ame="https://www.youtube.com/watch?v=uQb-iyiagT0"]2002 forester cold temp fuel leak - YouTube[/ame] [ame="https://www.youtube.com/watch?v=z3KkqKACuCc"]Wrx fuel leak - YouTube[/ame]
Sites visited:
https://forums.nasioc.com/forums/showthread.php?t=131755
https://forums.nasioc.com/forums/showthread.php?t=1680046
https://forums.nasioc.com/forums/showthread.php?t=1893471
https://www.subaruforester.org/vbulletin/f88/soa-finally-admits-fuel-leak-problem-101998/
https://www.subaruforester.org/vbulletin/f87/smell-gas-cold-starts-41319/
https://www.subaruforester.org/vbulletin/f88/fixing-leaking-fuel-gas-line-86782/index2.html
https://www.scoobymods.com/fuel_smell_cold_weather-t2886.html?t=2886
https://www.scoobymods.com/subject_wvk_21_recall-t11931.html?t=11931
https://z32.wikispaces.com/Fuel+Hose+Clamps
https://www.clubwrx.net/forums/gene...oting-accidents/134350153-raw-fuel-smell.html
..continued
Subaru Recall Campaign WVK-21
Dear Subaru Owner:
This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act. Subaru of America, Inc. has decided that a defect which relates to motor vehicle safety exists in certain 2002 & 2003 model year Subaru WRX vehicles that are currently registered in the following states: Alaska, Colorado, Idaho, Iowa, Maine, Michigan, Minnesota, Montana, Nebraska, New Hampshire, New York, North Dakota, South Dakota, Vermont, Wisconsin and Wyoming.
DESCRIPTION OF THE SAFETY DEFECT
Subaru has determined that in extremely cold outside temperatures, fuel seepage can occur from a fuel delivery line.
DESCRIPTION OF THE SAFETY HAZARD
The affected fuel line is located under the engine intake manifold. Especially during engine start-up in cold temperatures, fuel may seep around the seals between the metal fuel line and the rubber hose. Fuel leakage, in the presence of an ignition source, could result in a fire.
REPAIRS
To correct this condition, Subaru will replace the fuel line and hose with a later production version that has a longer rubber hose segment.
WHAT YOU SHOULD DO
You should immediately contact your Subaru dealer for an appointment to have the fuel line replaced. Please tell the dealer if you have noticed any smell of gasoline in the past when starting up in cold weather.
HOW LONG WILL THE REPAIR TAKE?
The actual time to replace the fuel line is approximately 2 1/2 hours. This will typically make it necessary for you to leave your vehicle for a longer period of time on the day of your scheduled appointment to allow your dealer some flexibility in scheduling and completing the repair.
Sites visited:
Code:
https://www.clubwrx.net/forums/general-maintenance-troubleshooting-accidents/134350153-raw-fuel-smell.html
..continued
