Go Back   OFFROADSUBARUS.com > Technical Forums > Under the Bonnet/Hood
Old 11th May 2018, 02:57 AM
turbo1600 turbo1600 is offline
Model: outback
Transmission: auto
turbo1600 is on a distinguished road
Default timing belt tensioner bearing
ever since i rebuilt the ej25 in my dohc 98 outback , there was this slight rattle for about a second or two ever since first startup ,if i let it sit for say 3 hours or more there would be less rattle/knock for a second , and if i let it sit overnight the knock / rattle would last a fraction longer.engine runs fine no knocking when acclerating or decelerating. i got block rebored, new oil pump , conrods resized, crank reground.
the timing belt seems to be a little slack, maybe...
i done some reasearch and read that the timing belt tensioner can cause this symptom.
i had two engines ( both ej25) one from a liberty 1999 wagon sohc , and the original from my dohc 1998 outback.
i have used the rebuilt sohc block with dohc heads.
and i just happened to notice the two timing belt tensioners are slightly differant , one has a bearing with a i.d of 32 mm , and the other bearing has a i.d of 35 mm. , i cant remember which tensioner setup i used from what engine...
now the two bearing i.ds are differant , does this mean the o.d of bearings is differant as well ?
and measuring from the top of the actual pin from tensioner there is a differance of about 1 mm. see pic .
i have been using the tensioner with the shorter length , and smaller id bearing.
does it matter which tensioner setup i use ?
mk
Old 15th May 2018, 10:48 AM
Model: outback
Transmission: auto
Default found cause of rattling / knocking !
the noise ended up being the hydraulic tensioner. i took of the timing covers, put the ballancer back on, and shoved a small crow bar thingy between the tensioner and the casting an " pumped " the tensioner a few times , started engine up an the noise has completely gone. even after overnite it still doesnt make the noise ! not sure how long it gonna last like that for but i`m putting in a new tensioner in tomorrow..
Old 15th May 2018, 06:43 PM
Good find - thanks for the follow-up
