Unread 17th April 2018, 02:00 AM
skep skep is offline
Year: 2003
Model: Forester xs
skep is on a distinguished road
Default Is sg and sh gearbox interchangable
Gday! just wondering if i can swap my built sg dual range box straight into an 09 sh? absolutely no info anywhere (that i can find) on it???
Cheers.
Unread 17th April 2018, 02:14 AM
I believe so. The SG runs 4.1 diff gears, and I believe the SH does too.
Unread 17th April 2018, 02:40 AM
Year: 2003
Model: Forester xs
cheers Rally.
yeah i was pretty sure but then thought they might have had a change in design that year.
Unread 17th April 2018, 07:52 PM
Yes they can swap but you might need to change the clutch, you always match the clutch to the gearbox not the engine.
The SG dual range gearbox & SH dual range gearbox should both be 4.111 diffs, but double check that. The single range gearbox from the XT will be 4.44
Unread 18th April 2018, 08:53 AM
It's interesting you say that Nacha, I'm running a gen1 ej22 with gen 1/2 flywheel and clutch setup in front of a Gen3/SG phase2 box - works no worries, even with my clutch cable
This box should, in my mind, be a direct physical swap. Differences could be electrical plug connection and diff ratio (of rear diff ).
Unread 18th April 2018, 10:38 PM
AFAIK, the only clutch difference you need to worry about in Subaru's is the change from push to pull type.
Unread 20th April 2018, 04:10 AM
Year: 2003
Model: Forester xs
thanks guys, appreciate it!
I have just put in a new clutch with the sg box so will transfer that as well with assembly if necessary
Unread 23rd April 2018, 07:48 PM
There are also subtle differences in height. They will fit but when you go to change gear, the clutch may not disengage if you have the wrong one
Unread 25th April 2018, 06:54 AM
for clutch / etc compatibility, use something like the exedy clutch finder:
http://www.exedy.com.au/clutch-finder
Both SG and SH 2.5 use FJK-7115 (for a single mass flywheel version).
Unread 12th May 2018, 06:33 AM
Year: 2003
Model: Forester xs
Ah good to know!! thanks for the heads up
