Go Back   OFFROADSUBARUS.com > Technical Forums > Bolt-On Bits, Accessories and Protection
  #21
Old 13th November 2016, 10:09 AM
Red XS's Avatar
Red XS Red XS is online now
Year: 2006
Model: SG Forester XS
I don't know where the nudge bars attach to. All I know is the aluminum reinforcement/crumple zone behind the plastic bumper and the steel mounting behind that is the same on both series of SG. So if the nudge bar bolts on to either of these they will be the same. Whether or not the nudge bar clears the plastic bumper is another question as they are different shapes.
  #22
Old 14th November 2016, 06:24 AM
havachat's Avatar
havachat havachat is offline
Tom,
The SG1 & SG2 have different front profile. The SG2 has a better approach angle. The ECB bars bolt on from underneath the subframe. The SG2 bar won't fit on a SG1.
  #23
Old 30th November 2016, 09:10 PM
What is the weight of a Suba X bumper? Any model.
2013 H6 5EAT OB with SubieLiftOZ kit, 2008 Tribeca
(2006 B9; 1995 Legacy wagon).
  #24
Old 1st December 2016, 12:53 AM
Once-upon-a-time I knew the answer but have forgotten now, and it's not on any of my paperwork. I think they are not very heavy, say around 22kg (59 lb).
  #25
Old 1st December 2016, 12:56 AM
Haha, metric is fine, too.
That sounds reasonable. It does not come with recovery points, does it? If it does not, why not? Because extra reinforcement (and hence weight) would be needed?
  #26
Old 1st December 2016, 06:54 AM
The gen3 outback one is about that weight -- can be carried by one person.
It bolts onto the OEM crash bar -- really its just a heavy aluminium cover. Not strong enough for recovery.
  #27
Old 20th May 2017, 11:15 PM
Rambler Rambler is offline
Year: 2006
Model: Forester X
Rambler is on a distinguished road
Posting a little info here as this seems to be the best resource for mounting Series I SG Forester Subaxtreme bars to Series II SG's. My series I bar was fitted to my series II car when I bought it without any mods, so it can be done that way. Basically the 'chopped' part of the original bumper is glued and screwed underneath the bar, covering the washer bottle and keeping the trim levels equal. Issue I had with this was that the car's approach angle wasn't improved, so I decided to do it the right way.
The neatest way to solve the issue of the exposed washer bottle & intake baffle is to take both from a Series I SG Forester from the wreckers. The Series I intake baffle is black, but otherwise identical in shape, making it impossible to see, and the washer bottle fits nicely into the engine bay behind the battery. You won't need to extend wires or hoses, and one of the bottle mounting points is already there.
To make the others, you'll need to drill a 32mm hole in this metal plate for the washer bottle to slot into.
Bunnings had a 5 pack metal hole saw drill set for $7 that included the right size. Reference photo is from the donor SG, series II SG has the same metal plate in the engine bay with two smaller holes drilled in it instead. I drilled a piece of cardboard first and used that and the photo as a guide to mark the spot.
One of the brackets you need is the one that the fuse box is already bolted to, however the second one is missing, pictured below in donor car. I got the bracket from the donor car and will get it tacked on at some point, but really the bottle is sturdy with just the two mounting points.
You'll need to pull the wires and hoses through to the engine bay, cut the heads off of the old washer bottle pump plugs and re wire them to the new plugs - I had an auto elec do this as I was having lights fitted anyway.
You'll still have to trim the wheel arches etc.
Finished
  #28
Old 21st May 2017, 05:33 AM
Looks great!
  #29
Old 20th August 2017, 03:15 PM
When the bumper is installed on models with a factory screw-in recovery eye-bolt, what happens to the recovery point?
My understanding is that the bumper does not come equipped with recovery points.
Is the end result no recovery point?
