Go Back   OFFROADSUBARUS.COM > General Forums > General Forum
Unread 11th June 2009, 03:41 PM
jg09 jg09 is offline
jg09 is on a distinguished road
Default What have you done to your car today?
If you're looking for somewhere to tell about your entire project plans, this isn't it. Just a little something about what you did today. Whether it's changing up your sound system, changing your oil, or finally finish up a big part of the project that you've been working on, etc., post it up here.
For me, I mounted my CB into the car. Just need to wire up the power and finish up my hidden stud mounting system for my 4' whips on the roof rack.
Unread 11th June 2009, 05:07 PM
07OregonOutback's Avatar
07OregonOutback 07OregonOutback is offline
07OregonOutback is on a distinguished road
Today, actually just about an hour ago, I cut my stupid fender liners at the front of the wheel well, as they kept getting ripped down when off roading and then would scrape along the ground. So annoying. So I got out my knife and did some modification.. and rotated the tires.
Unread 11th June 2009, 06:43 PM
Changed the battery in my key- winter has arrived and the central locking is getting a little grumpy early in the morning.
Unread 11th June 2009, 11:41 PM
frogstar7055's Avatar
frogstar7055 frogstar7055 is offline
I was here on day 1
frogstar7055 is on a distinguished road
Changed oil and filter,air filter,rotated tires on wife's my08.
Mine I just drove to work.
AWD..and not afraid to use it
Unread 12th June 2009, 01:00 AM
6 x new BFG AT's this arvo - that'll put a hole in the pocket!
Unread 12th June 2009, 03:56 AM
mr turbo's Avatar
mr turbo mr turbo is offline
Administrator and Founders' Friend
Year: MY05
Model: Forry XT
Transmission: manual
mr turbo is on a distinguished road
Mine was getting grumpy too, especially early mornings. I don't think thay liked being woken up that early to go to work so I decided to renew the battery keys also. Actually I did both of them.
We go anywhere & everywhere together as nothing's too hard in a Forry
Some call it Man V's Wild ...but here... We call it Camping
Unread 12th June 2009, 04:26 AM
Hux's Avatar
Hux Hux is offline
Hux is on a distinguished road
Lol I did my keys as well and I installed these seat covers that I picked up on the WE.
Cheers Hux
MY03 Forester, Silver, 2" lift, Subaxtreme bullbar
Unread 12th June 2009, 04:54 AM
eden's Avatar
eden eden is offline
bush bash'n ranga
eden is on a distinguished road
what size did you get?
cheers, Eden
2000 outback, subX bullbar + sumpguard,50mm raised strut blocks,30mm raised springs,215/65/16 rubber,uhf, dual battery system,150W spots,touchscreen navigation with oziexplorer. more to come
Unread 12th June 2009, 09:03 AM
Bumper Bumper is offline
Bumper is on a distinguished road
I just spent time looking lovingly at Fozzie, dreaming of places I'd rather be.
Last week I almost got a couplertec rust inhibitor fitter. All installed except the lead that runs to the back of the car. I have no idea how to get the lead from the engine bay to the inside rear wheel arch. Damn! And I thought I was doing so well. I can't see a way to safely run it under the car, so it looks like it'll have to go inside. I've never known how to get wires under the carpet or somewhere without making it look ike a dogs breakfast. Looks like I'll end up paying a sparky for this last bit
Kerri
2" lift - I drive a higher car!:lol:
Unread 12th June 2009, 10:04 AM
ian059 ian059 is offline
ian059 is on a distinguished road
Keep your money Kerri. Run the wire through any handy rubber grommet (use something pointy to make a small hole first) in the firewall (make sure you have access to the grommet on the inside of the firewall) and along the inside of your sill panel, under the carpet or just tuck it under the plastic trim/kick panels to the rear wheel arch or strut tower or stick it to the inside your 1/4 panel, as long as you have good contact with the metal. If there is a loop on the end of the lead instead of a sticky pad, just tec screw it to an inner panel or use an existing screw or bolt hole.
Let us know how you get on.
IanC
