Unread 8th May 2018, 02:48 AM
turbo1600 turbo1600 is offline
Model: outback
Transmission: auto
turbo1600 is on a distinguished road
Default o2 sensor wiring and test `98 outback 2.5 dohc
any body know what wires are what on the o2 sensor on my `98 outback DOHC 2.5, ?.
colors i got on plug ( male) are :
yellow / red
white
black / white
i looked thru a couple wiring diagrams , but nothing useable.
i put DMM lead on engine earth , an got + 12v on yellow / red wire , on o2 plug , but what are the other 2 ? which one is for the signal in, and heater earth. engines been wired up with a aftermarket sensor , two whites and black , i know the whites are heater, and black signal out.
i also connected my DMM to signal out from O2 sensor and got reading of average 450 to 550 mv, is this reading ok , i was sitting on bout 80 kph.
Unread 8th May 2018, 07:54 AM
not the DOHC - but the wiring diagram I have with the three-wire sensor has the same colours, so most likely matches.
YR - power
W - to ECU (shielded, shield grounded at ECU)
BW - Earth
450-550mV sounds pretty good.
Unread 8th May 2018, 08:52 AM
Model: outback
Transmission: auto
Thumbs up
dang ,,, excellent work !!! fanks.
Last edited by Kevin; 8th May 2018 at 06:55 PM. Reason: Unnecessary use of "Quote"
