Go Back   OFFROADSUBARUS.com > General Forums > Members Journals
Old 7th December 2017, 06:34 AM
Model: SG Forester X
Transmission: Stock 5 Speed Hi/Lo Manual
Rims the same for the moment although I'd like something a little lighter to balance out the added weight of the tyres and looking at going down to a 15" MT for when I do the trek to the cape,
Paint adds weight!
Shocks original and probably staying with the same (one needs replacing soon unfortunately, probably do both the front ones at the same time It doesn't make sense to do one at a time I reckon), ditto springs - don't want stiffer springs, I like comfort and as soon as you go off paved roads here you hit corrugations. I might even go softer!
Definitely want to upgade diffs and put in SF low range, just a matter of accumulating the parts so I can do it all in one hit.
I missed out on a WRX (2009?)that had been rolled at low speed (backed off a ledge) by someone I know, didn't even think of putting an offer in on it for parts. I should have, it was pretty clean. But then, I don't even know if any of the mechanics of it would have been suitable...
It wouldn't surprise me in the least if the local 'subaru guru' wreckers/mechanics got hold of it, use the parts for their race cars (which are all pre 2000)
They've got a nice little brumby they're putting a supercharger in too, shold be a fun little work ute!
I must go and see them again during normal working hours and have chat about what I'm after.
JackBeNimble JackBeSLO JackGoesWhereverYouCanGo!
Old 7th December 2017, 07:11 AM
Model: Outback
Cool. What diffs you thinking of putting there?
Steel rims much better and stronger for offroad. I would use them.
Yes stiff ride is bad . i think my front shocks are kinds too harsh on bad roads. Think they still original ones.
So how much your ground clearance now in front skid plate, exaust in middle and rear diff? Mine about 26 cm front skid plate and 28cm rear diff.so its about 10.2"
Changing shocks you need to do both so car would stay on same level. Best thing to change springs same time too. Like for example my front springs are changed and i think they slightly diff stiffness one side softer then other. So i would change both with both shocks.
Last edited by Kevin; 7th December 2017 at 08:40 PM. Reason: Unnecessary use of Quote
Old 7th December 2017, 07:35 AM
it's a shade over 300mm at rear diff with 215/65X16 on it, haven't measured anything else really, I should do.
Diff-wise, not sure yet until I find out what I can get. A DCCD would be high on the list i think. I like the thought of plated diffs front & rear, but not sure they'll be in the budget.
Main objective at the moment is making it a bit more water resistant. Going to try and get the snorkel in next week, then start plugging holes. Probably shift the ECU (my usual mechanic thinks that's a waste of time, he might not be my mechanic much longer, some of his workers are a bit slap-dash) and after that start delving into the transmission.
oh.. and try and figure out recovery stuff. Thinking of getting a box tow bar thing (the removable ones) front and back (have to replace the back, because it's not removeable) with anderson plugs nearby, then mount a winch on the removable bit so I can pull the car out from either end. when not in use, the winch can then live in the back of the car with the rest of the bits & pieces (Endgel, snatch straps, tools, spade, cutting equipment and so on)
Unless I win a fortune, in which case I'll buy myself an Iveco!
Old 7th December 2017, 07:50 AM
Model: Outback
Nice mods you thinking of. I could not afford those so i no thinking even.
So what mind trips you do? Short ones couple hrs or couple days with camping or even weeks?
I love camping and i found out that my trunk is more comfy to sleep in then tent . i did slept in mine for 2 weeks and it was amazing. I would do it for longer no problem if would have money and free time.
  #15
Old 7th December 2017, 09:27 AM
We tow a camper trailer and go camping a few times a year, pretty much drive to destination set up camp and that's it for a few days.
I've only just started building up the car for more adventurous stuff, so the few trips I've done off road recently have been day trips.
Not sure what to do with the camper trailer, thinking of selling it and getting something smaller (it's massive) and lighter, perhaps something that has a roof top tent on it and not much else, so I can fill it up with spare parts, fuel and water for the trips ahead! I've got a few planned for the years ahead.
My schedule for defined trips is:
1. Creb Track, theoretically just a day trip, but challenging, with a fair sized river crossing and a few creek crossings. If the car survives this, It will survive anything I'd want to do in it. This will be my "tester"
The two things that concern me about this track is the steepness (up and down several times) and the crocodiles in the Daintree river.
I aim to tackle this once the wet season is over enough for the ground to dry out and the river level to drop, although the way things are going with the wet season this year, I'll probably be able to do it over the Christmas break!
2. Tip of Cape York (Furthest point north while still on Australian mainland) taking the softer routes of the Old Tele track. Hopefully do this within the next two years.
3. Australia's "Longest Shortcut" to Perth, then home to Cairns via Broome & Darwin This one would be epic, hopefully do it before they pave it all
Then I could comfortably say I'd seen most of Australia, as I've already done most of the east and southern coasts and sizeable chunks of the middle. Oh, and Tasmania, the cold bit down the bottom.
There's some good video of both the Creb Track & the Old Tele Track on you tube, It'll give you some idea of what I'm planning on putting this car through!
  #16
Old 7th December 2017, 07:11 PM
That's true for 4WDs but not for Subarus. OEM alloys are very strong & light, OEM steelies bend easily & are heavy. Alloys are the way to go for our little Subies
Awesome !!!
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
