  #411
Old 4th November 2017, 02:24 PM
It’s a Harrop e-locker diff centre.
  #412
Old 4th November 2017, 02:51 PM
And it normally fits what 4x4 ? Nissan Terrano ?
  #413
Old 4th November 2017, 02:56 PM
Nissan Navara
  #414
Old 4th November 2017, 03:02 PM
Our recent trips off road with the car was with the interim R180 helical rear diff. We discovered that while the plated R160 had it’s limitations, it works better off road than the factory helical R180.
  #415
Old 5th November 2017, 09:27 AM
Which Elocker part number ?
A11120 or A11250 ? Are the 27 splines compatible with the r180 27 splines axles ?
I think it should work out...you will have to build some more and sell them !
  #416
Old 5th November 2017, 10:45 AM
Not sure about the part number. The Subaru axles fit into the diff centre. Main problem is axle retention and possibly length.
  #417
Old 17th November 2017, 06:51 AM
Work has now begun of getting the e-locker into the rear diff centre. As you can see, we now have been able t do this. Next step is getting the axles to fit properly.
  #418
Old 17th November 2017, 12:17 PM
Nice !
Is the crown a direct swap without mods ?
You had to use the grinder to take some metal off of the housing only to make the locker fit ?
Will you mahine some grooves in the diff splines to fit the axles, like oem ?
  #419
Old 17th November 2017, 02:27 PM
Yes, yes, not known.
  #420
Old 17th November 2017, 05:32 PM
Nice work Rally!
So what's the flat metal plate connected to? I'm guessing it's just floating since it's the electromagnetic plate stopper.
I hope you get a solution sorted for the driveshafts. Always the biggest hurdle.
