  #151
Unread 20th February 2018, 02:53 PM
scalman scalman is offline
Year: 2001
Transmission: 4eat
thats great man, make new ones .
  #152
Unread 20th February 2018, 04:39 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
I have a few in the picture gallery, will do some more next spring
Subversive...
  #153
Unread 20th February 2018, 05:44 PM
NachaLuva's Avatar
Nice track, bet there's some real tough ones around there, usually is in logging areas
  #154
Unread 26th February 2018, 12:14 PM
1WD Foz 1WD Foz is online now
Year: 1998
Model: Forester with a EJ22
Transmission: Manual 5 speed
Awesome vid !
Your foz dealt with that no worries
  #155
Unread 6th June 2018, 04:14 PM
Year: 2001
Transmission: 4eat
do you have some good flex pics from side with your new shocks ? or maybe even comparison before and after new shocks ?
found some
so that front wheel doesnt drop down so much more then stock does it . i mean just front wheel alone . i got it that all 4 shocks makes such great flex there. but anyone made some comparrison stock vs coils on numbers , like how much more they allow ?
  #156
Unread 6th June 2018, 04:24 PM
jf1sf5's Avatar
In the HotBits thread, first page, you can see some pics.
http://offroadsubarus.com/showpost.p...64&postcount=2
And if you look at the last video I posted (Morvan/France) going slow motion or pause, you can also see the suspension travel vs oem SF(beige) or SG/BG(green before the mud pit !)
Subversive...
  #157
Unread 6th June 2018, 04:28 PM
Year: 2001
Transmission: 4eat
but that oem was with all sway bars ?
ok so 60cm flex with coils vs how much with stock ? anyone measured that ?
  #158
Unread 6th June 2018, 04:48 PM
jf1sf5's Avatar
All three Foresters had no swaybars.
I don't go much lower than a 2" strut block lifted Subaru but I don't loose the thickness of the 2" blocks on compression. Its all about wheel travel/stroke, not ground clearance.
If I remember correctly, oem flex (diagonal spin) with swaybars was 27cm, without swaybars 42cm and HotBits 60cm (tire pressure 2,2bars/32psi)
Subversive...
  #159
Unread 6th June 2018, 05:02 PM
Year: 2001
Transmission: 4eat
now thats good flex there. sure its not all about ground clearance but you need to have some clearance first still.
that 42cm flex is forester your model flex yes ? wonder how well outbacks as mine do . i guess some worse as not same suspension design
  #160
Unread 6th June 2018, 05:44 PM
jf1sf5's Avatar
Not sure that you don't get the same flex as the Forester. You have a longer wheelbase on the Outback. The only way to know is to test it !
Subversive...
