  #131
Unread 18th March 2017, 03:34 AM
daniel glavin's Avatar
daniel glavin daniel glavin is offline
Year: 2002
Model: Outback
Transmission: Auto
daniel glavin is on a distinguished road
I'm glad you posted an update as it refreshed the members journal thread section and I came across your thread. I just poured through every page and read everything and watched all the vids. Very nice set up here sir. Keep the mods comming!
  #132
Unread 20th March 2017, 01:32 PM
nepbug nepbug is offline
nepbug is on a distinguished road
Originally Posted by jf1sf5 View Post
Little update.
I swapped the Forester's exhaust manifold and catalytic converter for an Outback BG exhaust manifold, up-pipe, down-pipe (with the catalytic converter) and kept the intermdiate pipe and muffler from the Forester. I'm very happy because I gained 2cm of ground clearance for free !
Sorry, for those who don't know, the Ouback BG exhaust (na) takes the same route as the turbo Foresters above the front right CV axle for left hand drive Subarus, don't know about the right hand drive Subarus though.
I think you meant to say that the BG outback routing is the same as the NA forester routing? Also, BG outbacks didn't have uppipes and downpipes, that's turbo applications only, I'm not sure what you're referring to there.
You swapped an NA BG Outback manifold and cat to your SF NA Forester right? I don't think there were any turbo bits involved if I'm reading this correctly.
BTW, very nice flex pictures, really impressive!
Edited to add: Oops, didn't realize there was so much difference between USDM and EDM BG outback exhausts, clarified here: http://offroadsubarus.com/showpost.p...&postcount=135
E . ` ' / . F
  #133
Unread 20th March 2017, 05:47 PM
jf1sf5's Avatar
jf1sf5 jf1sf5 is offline
Hi Nick !
No, no ! I meant what I wrote ! I have installed a BG Outback 2,5 150 bhp NA exhaust that has the same routing as a turbo Subaru ! I'll have to take some pics
And where are your Subaru projects ?
Subversive...
Last edited by Kevin; 7th December 2017 at 07:47 PM. Reason: Unnecessary use of Quote
  #134
Unread 21st March 2017, 05:38 PM
jf1sf5's Avatar
Tease before pic...
https://partsouq.com/en/catalog/genu...bg9lfbwgo89558
Subversive...
  #135
Unread 27th March 2017, 12:58 PM
Oh wow, I learn something new everyday. The EDM BG outback exhaust is drastically different than the USDM BG Outback exhaust.
Here's USDM:
Here's EDM:
Now I see what you're talking about. We were both correct for our respective countries. I wonder why the EDM and USDM are different.
In the US, the 06+ Imprezas switched to a similar header, but they never had the up pipe and down pipe that you have, strange stuff.
E . ` ' / . F
  #136
Unread 27th March 2017, 04:30 PM
Rally's Avatar
Rally Rally is offline
Year: 2004
ADM looks the same as USDM.
SG turbo, 99 WRX, PX2 Ranger
  #137
Unread 27th March 2017, 07:20 PM
NachaLuva's Avatar
Very strange lol
  #138
Unread 9th April 2017, 08:38 AM
jf1sf5's Avatar
I'd be interested to see this too
Sorry, didn't respond...here is a pic of the rear modified SG spring perch/top hat
http://www.forum4x4.org/threads/1175...=1#post3105126
Subversive...
  #139
Unread 27th July 2017, 02:44 PM
jf1sf5's Avatar
Update !
The Heri axles were getting a lot of play and needed to be replaced but I couldn't find any other axles on the market that could do the job with the HotBits coilovers.
Went to the junk yard to see my friend and had a look at the Subaru CV axles. One of them was bigger than the others so I started measuring it. It was just 1cm longer compressed an 5mm longer at full extension compared to the SF CV axles. Another difference was the size of the cups, they were larger too and could take an angle of 30 compared to the 25 of the normal Subaru axles (Forester, Impreza, Legacy...)
Enough said, this Subaru SVX axle was like a treasure in front of me ! So I bought it and started to look for a 2nd one.
The modifications needed to fit the SVX axles to the SF drive trains is to machine down 3mm of the outer cv to fit the wheel hub and swap for SG front A-arms because of the 1cm longer compressed length.
SG front A-arm bushings need to be cut 6mm (3mm/side) to fit the SF chassis.
Also replaced the boots with light truck boots, the same I had on the Heris for 30 months without any issues.
At last, I put the Foz on a car lift, wheels dangling, 2nd gear and its just perfect !
Subversive...
  #140
Unread 16th August 2017, 12:07 AM
Escher's Avatar
Escher Escher is offline
Senior Member
Escher is on a distinguished road
Axles from the SVX in a Forester? That would be epic!
MY06 Forester, Primitive 1" lift, King HD springs.
