Go Back   OFFROADSUBARUS.COM > Trading Post > Wanted
  #1
Unread 2nd September 2017, 08:32 PM
skep skep is offline
Year: 2003
Model: Forester xs
Transmission: Manual
skep is on a distinguished road
Default 1.447 L/R Gearset (can swap w/my 1.59) & front 4.44 R/P
gday!! I am after a 1.447 low range gearset, 4.44 front ring and pinion and 0.738 5th gear set.
I have a 1.59 L Series I can swap for the 1.447
Thanks.
  #2
Unread 3rd September 2017, 01:27 AM
Rally's Avatar
Rally Rally is offline
Year: 2004
How long can you wait? I will have the low range gears available in a few months.
SG turbo, 99 WRX, PX2 Ranger
  #3
Unread 3rd September 2017, 10:26 PM
Year: 2003
Model: Forester xs
I have taken 3 weeks holidays starting early oct and will be doing a full overhaul on the sg including gearbox with a half dodgy bearing and oil seal at the back of it so only really have the opportunity then mate! cheers
  #4
Unread 5th September 2017, 02:34 AM
NachaLuva's Avatar
The 1.447 LR with a 4.44 diff is a good combination, but you'll have to machine the crown wheel to clear the LR gearset. Doesn't need much off apparently
  #5
Unread 6th September 2017, 06:14 AM
Year: 2003
Model: Forester xs
yeah its pretty close to the l series and safer, I have sourced the 1.447 now and 4.44,0.738 from alldrivesubaru so no longer looking thanks everyone... Hopefuly I can swap my rear ring n pinion from my GT foz diff onto my SG rear diff to keep my axles... It was hard to find a replacement rear axle when I ripped it out accidently because there were 3 types for that model apparently
