Go Back   OFFROADSUBARUS.com > Technical Forums > Electrical and Lighting
Old 28th October 2017, 06:09 AM
Model: SG Forester X MY05
Transmission: 5MT D/R
? because
Originally Posted by lefty View Post
My latest project - Hella Comet 500 spotties behind the grill
I guess that is better than drilling holes in the bumper
Last edited by Ben Up North; 28th October 2017 at 06:23 AM. Reason: Because it probably wouldn't flex
Old 28th October 2017, 07:33 AM
SquiresSquire SquiresSquire is offline
Year: 2007
Transmission: DR 5MT
SquiresSquire is on a distinguished road
I remember a post on SubaruForester.org where the bloke welded some bar together and mounted it in front of the radiator off existing bolt holes
Old 28th October 2017, 08:33 AM
That's pretty much what Left has, afaict. I think it goes on to the existing bumper mounts. This would mean it might be able to be fitted without removing the entire bumper.
Old 1st December 2017, 09:45 PM
My mate Eric has finished plasma cutting the old bull bar I'm using for mounting the lights on (chopped out a section of it anyway). Tha bar will sit behind the grill, with two tabs coming out, ending at just about the front of the grill that the spotties will bolt to. It's 4mm thick right angled aluminium, shouldn't wobble.
Even more hopefull, is I've got the height right.. too high and the top of spots will be above the bonnet (which is a no-no, from what I can tell).
I've got a little bit of height adjustment, but not sure enough.
Will post progress picks of it from here, once I get it back!
JackBeNimble JackBeSLO JackGoesWhereverYouCanGo!
