Go Back   OFFROADSUBARUS.COM > Offroad and Touring Central > Trailers and Vans
Unread 18th March 2017, 06:07 AM
imoyle imoyle is offline
Junior Member
Year: 2015
Model: Forester 2.0DL
imoyle is on a distinguished road
Default Towing mods required
We have a Subaru Forester 2.0D-L and have an off road camper ordered. The camper weighs around 1300kg. The turbo diesel Forester can tow up to 1800 kg.
Any suggestions about modifications that would make for a rewarding towing experience both on and off road e.g. Improved suspension, all terrain tyres, underbody protection etc.
Unread 18th March 2017, 06:55 AM
GreenSuby GreenSuby is offline
GreenSuby is on a distinguished road
You'd need to check what the ball weight of the camper is. If it's a forward fold, the ball weight could be around 200kg loaded.
Not sure what the tow ratings are for my sg forester, but if i hooked up our forward fold to it i reckon it would pull the arse out of the forrester.
Greensuby
Unread 18th March 2017, 07:11 AM
CVT ? I'd be looking carefully at what mods like trans cooler may be required.
1300 is a lot -- and no doubt you'll put stuff in it (water, gas, bedding, etc).
Unread 18th March 2017, 07:19 AM
Junior Member
Year: 2015
Default Towball download
Thanks GreenSuby
Towball download is 90 kg, with plenty of leeway before reaching the 10% weight limit of 180 kg.
Unread 18th March 2017, 08:19 AM
Junior Member
Year: 2015
Default CVT
Yep the 2.0D-L is a CVT. Have heard conflicting views about the need for transmission cooler
Unread 18th March 2017, 04:02 PM
Rally Rally is online now
That must be some trailer. My camper is no lightweight at 750ish kg loaded. I would definitely recommend electric brakes if the trailer has them. And if not, get them fitted somehow. When you are going down steep dirt tracks you wouldn't want to have anything else. Also can help stabilise the trailer if you get swaying. Get a sump guard, and with that low mounted turbo, be mindful at water crossings what cold water will do to a stove hot turbo. I would be interested to know what the argument against a cooler is. What model of camper trailer did you get?
Unread 18th March 2017, 05:15 PM
Junior Member
Year: 2015
Default the camper
Thanks Rally
The camper is a Rhinomax Scorpion; with significant off road creds; hence the 1300 kg.
Yes it has electric brakes and we have a Redarc Towpro brake controller in the Suby. I've heard a number of times now that a sump guard is a given; thanks.
As for the transmission cooler, I've read elsewhere on the forum that advice from Subaru Australia is that a transmission cooler isn't necessary in the Forester. Many others have said it's necessary.
Unread 18th March 2017, 08:13 PM
Once you include water and other bits and pieces, you will be nudging 1500kg. I think I'd be including an oil cooler. Not just for the gearbox, but the engine as well (with thermostat).
Unread 5th April 2017, 11:43 PM
founts founts is offline
Junior Member
Year: 2015
Model: Forester 2.5i-L Special Edition
founts is on a distinguished road
I've got a 2015 2.5 CVT and tow both my camper trailer (750kg) and boat (1300kg) with it no problems. I've towed both long distances including dragging the boat up to Lake Eildon in summer and never had any trouble with the CVT. I usually use S mode when towing the boat to increase engine breaking on down hills and improve throttle response. But that said the usual rules apply, take it easy.
Unread 5th April 2017, 11:49 PM
Junior Member
Year: 2015
Default CVT
Thanks Founts - appreciate the positive support
camper trailer, modifications, towing
