Go Back   OFFROADSUBARUS.COM > Offroad and Touring Central > Trip Reports
Unread 15th May 2018, 03:13 PM
Default Chapka 2018
Went for the annual trip to Auvergne, France, and met up with friends and new people. Its always a good moment as we eat well, have good laughs and find some new tracks. We all sleep in our tents even if its raining, like it did this year...
We had to build a "bridge".
https://youtu.be/Ljf8l9cGxKU
Unread 15th May 2018, 03:34 PM
scalman scalman is online now
so why you not on video. how you passed it ? that toyo had just open diffs there or some kind of lockers ?
Unread 15th May 2018, 04:01 PM
I have a video, I have to upload it on Youtube !
Here is another one, seems easy with the Forester...
https://youtu.be/YzZlyyiN1oA
Unread 15th May 2018, 05:56 PM
it is indeed seems easy but cool. im thinking now that those heavy but famous 4wd cars must put so much more work to pass those same spots and because they try so hard they kinda look cool because they slide all over and have hard time. all because they weight a lot and thats their main problem. you must compensate that with so much power and grip to go anywhere with big 4wd. not so much problem with light subaru.
p.s. i found more videos there , they pretty cool
Unread 15th May 2018, 07:45 PM
I've read that you are much better off putting logs at right angles to the car if you are doing this sort of thing, much less risk of the logs spiking the car if they snap or the tyre flicks them up.
Which kinda makes sense...
Unread 16th May 2018, 03:19 AM
Off-topic discussion moved here: https://offroadsubarus.com/showthrea...t=6867&page=18
Unread 16th May 2018, 03:26 AM
That's right but we were lazy !
Two days later we went back with more big 4x4's and built it the right way
Unread 16th May 2018, 03:46 AM
Same uphill section with a Toyota
https://youtu.be/X-n_AmWiuDc
Unread 16th May 2018, 04:02 AM
Subforest's green Forester has 2" lift on SF front struts, Outback BG rear struts, 235/75 15 Hankook mud tyres, EJ25 swapped engine, rear Vlsd but oem low range (1,447:1) and center differential.
https://youtu.be/ZOYtrPbe2v8
Unread 16th May 2018, 04:07 AM
Just for you, Scalman !
https://youtu.be/DrdYK6zu440
