  #1
Unread 31st July 2013, 09:19 PM
stilson's Avatar
stilson stilson is offline
stilson is on a distinguished road
Default Swap and flip lateral arms.
This came up in a threadjack elsewhere...
Why do I want to do this?
What car can I do this on?
What are lateral arms?
Pics?
The Grey Fox - MY08 SG XT Luxury
  #2
Unread 31st July 2013, 11:36 PM
NachaLuva's Avatar
They run between the diff carrier & the wheel hub. The sway bar link attaches to them:
When lifting by 2", instead of getting longer links you can invert the arm so the link attaches to the top instead of underneath, effectively raising the attachment point by ~2" matching the lift.
Simply put the RHS arm on the LHS & vice versa, so the arms are swapped sides & inverted
  #3
Unread 1st August 2013, 05:12 AM
Tannin Tannin is offline
Senior Member
Tannin is on a distinguished road
Dumb question #2: why would you do this? What does it achieve? What happens if you don't do it?
tannin.net.au
  #4
Unread 1st August 2013, 05:17 AM
yarney's Avatar
yarney yarney is offline
yarney is on a distinguished road
You will snap the links there is too much strain on them they are only plastic
Jan
Subies will go anywhere
Tags
arm, flip., lateral, lift, link
